Old 24-06-2007, 11:12 PM   #1
hegemon
Default Gearbox compatability
Gday,
It looks like I might need to replace my gearbox - normally a fatal problem on a $1000 car BUT, I've found a cheap one which could fit...
It's a 5sp. box from a 1.6lt carby KH Laser. My car is a 5sp KE carby.
Would the KH box fit in my KE?
Cheers.
hegemon is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2007, 10:18 AM   #2
dirty hands
Over Thinker
dirty hands's Avatar
have to wait for a laser guru to respond to that one
5 speed to 5 speed ok
ring a ford wrecker for a quicker answer
its the clutch spline
and do the housings to the motor and bolt holes match up
next the length of the cvs drive shafts
best get out the tape measure
dont forget to put in new cv joint seals on the box :togo:
My car goes Brumm Brumm
Old 25-06-2007, 11:28 AM   #3
VippiN
What a performer!
VippiN's Avatar
Originally Posted by hegemon
Gday,
Cheers.
Nope, they're different. You can use boxes from the KA,KB,KC,KE but personally i'd only recommend the KC,KE.
They're like $150-$200 from any U-PULL-IT/PICK-A-PART type wrecker. Cheap and common. Anything but a fatal problem.
1981 Ford Laser KA :: E5 :: 2002-2003
1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW
1990 Ford Laser KF TX3 :: BP :: 2010-2011
1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW
2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW
1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020
2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-*
1998 Ford Falcon AU XR6 :: HP Intech :: 2021-*
VippiN is offline   Reply With Quote Multi-Quote with this Post
