Got a little water in px3 on weekend on pass side , electronics started playing up after that steering , hill assist , cruise control , ESC , pulled seat our and found a modual on floor , xmckeaned and dried it , my question can this be the cause and what it called if I need to source another
hi
Water ingress can fry electronics today and in the future . The future problems can be caused by moisture or developed corrosion over time . If your unlucky modules that are wired to the wet unit may fail in the future also . The wiring because companies use the smallest possible size can fail as moisture wicks itself up the cable from connector and corrodes wires internally . The signal or power flowing thru can be intermittent . Obviously the above issues can be difficult to diagnose . In a simpler car all the dash and engine loom is removed dried and lubed . All ECU are removed and dried . About 7 --10 days work . No guarantee . |
#3 | |||
As for your problems, maybe so or maybe not. |
how and where? Ranger is rated to 800mm deep wading so all the critical electrical joints should be above that.
800mm wading, not immersion...
well, it's 800mm at <7kmh, so pretty much immersion
No, not its not, you cannot park in 800mm water.
The Silver Bullet - BJ74 Where the actions at Ontrack 4wd Club https://www.facebook.com/ontrack4wdclub |
maybe OP can explain a little more?
