Old 06-06-2007, 08:29 PM   #1
loony888
loony888's Avatar
Default sports bar removal??
g,day all, one for the ute owners amongst us, my alloy sports bar is looking tatty so i want to take it out and refurbish it. (i'm getting it blasted and powder coated white, to match my paint) i thought it would be simple, but i tried un doing the bolts that locate it and one behind the cab came out and a nut fell through to the floor, now i can't get that nut between the tub and cab and i chickened out and did the others up.
is there a specific way to remove and even more important, refit this bar assembly??
thanks in advance all.
paul.
i was going how fast officer?
loony888 is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2007, 08:34 PM   #2
b2tf
not here much anymore
b2tf's Avatar
dont know mate but i would be very interested to find out too, mine need to come off for a clean as well.
2024 F150 XLT
Old 06-06-2007, 09:01 PM   #3
Tech Trainer
Are you sure about that?
Tech Trainer's Avatar
When I had my ute I let them fall out and replaced them with riv-nuts. Makes life a lot easier when you remove it next time.
Tech Trainer is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2007, 09:16 PM   #4
Orbit
Resident Nyctophobic!!
Orbit's Avatar
20min i can take yours off B2TF. PM me and i'll come and do it.
It's pretty straight foward to take off. 6 bolts total 2 are panel screws at the cab end. and 4 are nut and bolt or bolt and threaded tab depending on the model.
ORB.
Orbits secret to life: Eat less, move more!
Orbit is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2007, 09:31 PM   #5
b2tf
b2tf's Avatar
thanks mate, pm sent. maybe when its being done we should take some pics or something for the rest wanting to know how to do it.
2024 F150 XLT
Old 09-06-2007, 05:32 PM   #6
loony888
loony888's Avatar
thanks tech trainer, can you explain "riv nuts" please??
Old 09-06-2007, 08:15 PM   #7
Umineko
Karasu
Umineko's Avatar
More comonly called "Nut-serts" it's a method of inserting captive nuts into sheet metal using a thing that looks like an oversized pop rivet gun, same principal, the nut is inserted into the hole and then a collar attached to one end is compressed like a pop rivet to hold the nut in place permanently. They are great things except if you over tighten the bolts you can start them turning in place and then they are damned hard to get out
Umineko is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2007, 05:44 PM   #8
loony888
loony888's Avatar
ahh, thanks! i know what they are, and i have a mate with the gun, so he might have the right size nut serts too.
