Old 22-12-2008, 09:07 PM   #1
josh_hartman
Default Will standard AU3 XR8 ecu run a 347?
as the title suggest will the ecu run a stroker motor. im considering stroking my 220kw engine
josh_hartman is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2008, 09:10 PM   #2
AU1XLS
AU1XLS's Avatar
Edit it Josh
AU1XLS is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2008, 09:12 PM   #3
philstoj
philstoj's Avatar
Yes it will run it but to optimise it you will need to tune it.
philstoj is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2008, 09:12 PM   #4
b2tf
not here much anymore
b2tf's Avatar
Mine had enough trouble running a bigger cam, I wouldnt try it on a 347
2024 F150 XLT
Old 22-12-2008, 09:14 PM   #5
josh_hartman
ok i would get an edit but im in a country town and there is no tuners around so it makes it a bit hard. just wanted to know if it would be safe or could even drive 400km
Old 22-12-2008, 09:15 PM   #6
philstoj
philstoj's Avatar
The engine size upgrade wont affect it, its the cam depending on how big you go that the ECU will struggle to handle.
Old 22-12-2008, 09:16 PM   #7
b2tf
b2tf's Avatar
I drove mine unedited with the cam in it for 400km to Melbourne to be tuned and it was fine apart from being a pig on fuel
2024 F150 XLT
Old 22-12-2008, 09:16 PM   #8
T3man
T3man's Avatar
It will run it OK with an edit (flash tuner). Just remember the standard 220 settings may be very lean with the stroker motor so no full throttle load until you can get it to a tuner and have the edit box tuned. Drive it the absolute minimum distance possible until you can get it tuned.
Old 22-12-2008, 09:31 PM   #9
RG
Back to Le Frenchy
RG's Avatar
It will be very lean and idle like a cow, mine was near on undriveable with the factory settings.
Old 22-12-2008, 10:15 PM   #10
CAT600
I miss my wheelbarrow
CAT600's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always willing to help out fellow AFF members... Technical Contributor: For members who share their technical expertise. - Issue reason: Daniels knowledge of modular engines and superchargers is extremely valuable to the AFF community. I have learnt quite a bit just reading his build threads. His contributions are often utilised by other members.
Everyone gives a different report on what will and wont run.
STROPP still has an AU XR8 pcm, (with the XR8 file) in his T3 TE50 after it crapped itself on the nullabor. It runs as strong as any of them and has given no sign of having issue.
Peeler has a centrifugal blower on his P250 with the standard T3 pcm file, and has run like that for longer than I have known him.
So it really does seem almost like pot luck, as I know what a heavily cammed 5.0L will run like unedited, but that is mostly base idle speed that makes it a pig.
The biggest thing is that the Maf and the injectors are matched to each other, and that the injectors are matched to the factory pcm tune.
Daniel
CAT600 is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2008, 10:42 PM   #11
philstoj
philstoj's Avatar
Daniel
I agree mate, and it all depends on the specs of the motor to be built.
With an XR8 maf no way will it run lean, different if you run a 90mm ford racing maf...
Old 22-12-2008, 10:47 PM   #12
CAT600
CAT600's Avatar
Originally Posted by AU1XLS
Edit it Josh
And really when it comes down to it, the first reply is the only proper solution.
Daniel
Old 22-12-2008, 10:48 PM   #13
EvilChief
Boost Addict
u can always play with an adjustable FPR as a short term solution till u get it to a tuner
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2008, 11:46 AM   #14
mickyyyy
Have the flash tune it especially if ur going to run a bigger cam. Plus is dosent cost much to do a flash tune epecially if your gona build a 347 stroker.
mickyyyy is offline   Reply With Quote Multi-Quote with this Post
