Old 25-05-2011, 10:32 PM   #31
superroo
You can't stop the signal
superroo's Avatar
Default Re: Smartlock/ Smartshield (Series 1 to 1.5) HELP!!!
I'm thinking that the key reader is different.
Series 1 has four wire key reader and series 1.5 has a 5 wire key reader.
Between the car and the dash, I pretty sure they are the same
Old 25-05-2011, 10:38 PM   #32
KR1STO
Just another mock-up..
KR1STO's Avatar
where is the key reader..?
Will that be something that I am changing...
I'm basically putting in the whole TS50 dash and associated looms..
Including the Complete TS50 Steering coloumn and loom..
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2011, 11:22 PM   #33
superroo
superroo's Avatar
If your changing the column, your changing they key reader.
PS.
For those of you playing at home, it is the plastic device that is around the ignition barrel (separate to the barrel)
Old 25-05-2011, 11:39 PM   #34
KR1STO
KR1STO's Avatar
That's great..
Thanks again mate.....!
see my car here:
[SIGPIC][/SIGPIC]
Old 26-05-2011, 12:25 AM   #35
FAT245
Lacking Imagination
FAT245's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Nath deserve's a Technical Contributor award for his willingness to share everything in his vast knowledge of tuning EEC-IV and -V Falcons, not to mention engines!
Done yet?
My 11 Second AU Fairlane
364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W
FAT245 is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2011, 01:49 PM   #36
KR1STO
KR1STO's Avatar
Yep...!!! hahah
Thanks to everyone for the info and tips.. It's greatly appreciated guys..!!
Its all working, no probs with Smartshield at all...
Everything plugged in and is operating perfectly..!!
Here's how she's sitting at the moment.. still a bit to do but the main thing is.. Everything works..!!!!
Also, here's a vid of the ESS engaging..
Thanks again guys..!!
see my car here:
[SIGPIC][/SIGPIC]
Old 26-05-2011, 04:28 PM   #37
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
Fix Your Filler Cap
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2011, 05:05 PM   #38
KR1STO
KR1STO's Avatar
hahaha.. It was open..!!!
Ok, one more question..
It seems now my indicators don't flash...
they just stay on when turning...?
It seems intermittant though.. sometimes they'll flash, sometimes they will just hold the light on until turned off..?
Any ideas on what's going on there...??
Kris
see my car here:
[SIGPIC][/SIGPIC]
Old 26-05-2011, 05:17 PM   #39
POELWYK
POELWYK's Avatar
check your relay in the fuse box as it might be getting stuck... i had this problem after i changed the relay it worked fine
2001 AU Falcon
Old 26-05-2011, 05:19 PM   #40
KR1STO
KR1STO's Avatar
Yeah just did a bit of searching (should have done that first..lol) and I'll change the flasher relay with my original one.. should fix it...
Cheers mate..!
see my car here:
[SIGPIC][/SIGPIC]
Old 22-09-2015, 09:06 PM   #41
monroc
Hi mate I was just looking at your post I have a series 1.5 ute and I have just put in a series 2 ghia dash with the heater box and climate control basically the same as you did you change all the engine bay wiring as well and did it start and work for you I am getting a bir perplexed abour all of this another fellow was saying I had to change all the engine bay wiring as well I am spinning lol could you let me know how you went ... Thanks mate regards steve
monroc is offline   Reply With Quote Multi-Quote with this Post
