Old 23-09-2005, 11:13 AM   #31
xr8ute
Back on the road
xr8ute's Avatar
Originally Posted by Headsex
In my instance, it will give me total control over forced induction (with bigger injectors, and bigger Maf obviously)
Exactly, you've only got to look at the States to see how correct this statement is. They have had this sort of tuning solution for years. Would be good to see the same thing happen in Australia.
I've already got my MAF, injectors, S-Trim ready to go.
Just need to wait for this edit to be released (and fix my diff)....Happy Times!! :
Old 23-09-2005, 02:13 PM   #32
Gambit
Gambit's Avatar
All the testing seems to focused on the auto vehicles which is great if you own one but will there be much difference in the manual vehicles?
Gambit is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2005, 07:35 PM   #33
Headsex
headsexTuned
Hi Gambit ... Just so you know, As well as mine being first AUTO AU tuned.. There was a Supercharged (powerdyne) Manual AU in herrods workshop which was tuned also.. With great results.. Even though he had stock injectors, FMU, and pegging maf. (eww)..
Headsex is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2005, 07:54 PM   #34
NZ
NZ's Avatar
Are you able to get a transfer function for the stock AU 70mm maf??
Old 23-09-2005, 07:57 PM   #35
NZ
NZ's Avatar
Originally Posted by parawolf
Indeed but don't forget you alter your tyre profile - as the added circumference will be like dropping going to a taller diff ratio (not a large impact, but on the search for more torque... ripper).
Lightweight wheels = lower unsprung weight which means better handling and suspension response
Lightweight wheels = lower rotational mass which means less interia (and in fact lower gryoscoptic effect which could mean a long lasting LSD at speeds.
Lightweight wheels = lower rotational mass which can also give a similar effect to a lightweight flywheel which again is kind of similar to a underdrive drive mount assembly pully configuration (faster reving!).
All good things!
Dude. just tell them to spin on their office chair!
If they spin, then hold something heavy as they move their arms out they'll slow down. when they pull their arms in they'll gain speed again. Its an easy way to show dummies in a practicle way
Old 23-09-2005, 09:20 PM   #36
Headsex
headsexTuned
You want the stock values?
PM me with what you exactly want, and i'll help where i can..
danny.
Old 23-09-2005, 09:52 PM   #37
parawolf
beep beep
Dude, when someone wants a proper explanation in regards to why things are; spinning in the chair vs telling why something is the case in relation to something else in the car or other similar modifications I reckon is a better to explain using more relevant descriptions.
It might be long winded, but its proper...
Nothing to see here, move along, move along...
parawolf is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2005, 01:51 PM   #38
loxxr6
XB in parts...
loxxr6's Avatar
That's just what I wanted to hear. Looks like this is definately on the buy me list.
Old 29-09-2005, 07:54 AM   #39
AUIII XR8 MAN
DJR TM#54
AUIII XR8 MAN's Avatar
So hows the tunning going?
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went.
Now Zetec Powered. 1.6lt of madness. But the XR8 still remains
AUIII XR8 MAN is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2005, 08:14 AM   #40
jonbays
TL40 Wagon?
Whats all the talk about 19" wheels affecting the power?
All they will do is change the effective gearing and move the powerband up to a higher speed but not rpm.
low profile tyres would mean this wouldn't necessarily be by much either.
The lightweight wheels stuff is all way out there too.
The theory is good but practic;y the difference on a dyno or the track between a car with 15' steel wheels and 19" alloy wheels will only be the gearing difference nothing else.
lets get back on to the edit program which i want to see if it can also do MAP I6's not just MAF V8's.
Old 29-09-2005, 06:42 PM   #41
YOOT
YOOT's Avatar
I agree with you but unfortunately at many a dyno day on teh turbo forums every single car that had 19s lost power. Why? i don't know.
We even went as far as changing a car on 17s to 19s and measured a 15rwkw drop, and vice-versa when the 17s were returned.
Its just goes to show how inaccurate dynos are, but more importantly they are just a tunign tool. Before and after is what counts. Nothing more.
YOOT is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2005, 05:56 PM   #42
SWOOP
XRSVO
SWOOP's Avatar
any more news on this?
itch'n to get it done
SWOOP is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2005, 08:54 PM   #43
Headsex
headsexTuned
Getting there.. Last few days i've been playing with the Shift Torque Reduction...
I now have full engine torque between shifts, and rather than being a firm shift (with my shift kit), it wheelspins when 2nd gear engages.. Noiceee!!
Let you know more as i know more
Danny.
Old 03-10-2005, 10:08 PM   #44
Grunter
Not of the Sooty variety!
Grunter's Avatar
Hell I'm looking forward to being able to **** off (or at least manage) the torque reduction and being able to control the auto.
Bring it on!
"To be afraid is to be alive - to act against that fear is to be a person of courage."
Current
The Toy: 2002 AUIII TS50
The Daily and Tow Vehicle: 2016 VW Amarok
Grunter is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2005, 11:45 PM   #45
Headsex
headsexTuned
Bring it on!
I knew you'd show your face sometime soon
Did andrew tell you something he shouldnt have????
danny.
Old 07-10-2005, 02:19 PM   #46
jimt3te50
My kids think I'm cool
jimt3te50's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Jim has consistently for some time now shared his life, and his passions in his XY GT and more so his FG GT in a way so everyone here feels part of the journey, which helps make AFF such a worthwhile place to be.  An outstanding contributor in my book.
need to keep this at the top of the page so i don't lose it!
does it look like this will be available soon, say next 2-3 months?
2011 FPV GT 335 >My Build Thread<
(Posts 3511-3515 has a compilation of most of the pics, page 118 @ 30 posts per page)
BLUESTREAK built 5.2L flat-plane-crank VOODOO with 3.2L Intercooled Kenne Bell blower, 1000rwhp/746rwkw @ 8000rpm @ 20psi on E85. Built ZF with BLUESTREAK 2C Circle D converter. Unbloodybelievable...
2018 Ford Ranger RAPTOR
2013 Audi SQ5
jimt3te50 is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2005, 02:29 PM   #47
Headsex
headsexTuned
As for the time frame, i cannot quote that.. Im just a tester.. What needs to be done after this is upto somebody else
Capa might have a better idea on when its available..... But i say, it will be soon.. Much sooner than before
Danny.
Old 07-10-2005, 09:43 PM   #48
Bossxr8
Peter Car
Bossxr8's Avatar
Danny.
Will it work on earlier models such as EF-EL.
Old 08-10-2005, 11:19 AM   #49
Headsex
headsexTuned
At this stage, as its Flash Based. No, as the EF-EL eec-iv ecu is not flash based.
Old 08-10-2005, 03:36 PM   #50
FTE217
T3/Sprint8
FTE217's Avatar
Danny any new dyno figures ?
Like my kids ask " Are we there yet ?"
Pricing will be interesting, the BA flash was something like $1500 - $1600 wasn't it guys ?
Now I see it advertised for as low as $800 - $900.
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
"Don't believe everything you read on the internet. Abraham Lincoln"
FTE217 is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2005, 05:18 PM   #51
xr8ute
Back on the road
xr8ute's Avatar
Will the same SCT Advantage software work with SCT's USB chip burner? Then it would just be a matter of cracking the definitions and CAPA supplying the ship hardware. 4-position flip chip would be nice.
I suppose adjusting Auto Trans functions would be not possible for E-Series with their external Trans Control Unit...
Old 08-10-2005, 05:20 PM   #52
xr8ute
Back on the road
xr8ute's Avatar
I am keeping a close eye on my wallet, and the CAPA website too...lol
Bad time of year for money though. Maybe if I don't drink any beer, and give everyone $2 scratchies for XMAS......:
Old 08-10-2005, 07:57 PM   #53
12
Silhouette AU1 TS50.
12's Avatar
Yeah.. I'm also interested in this. I've had this idea of having 3-4 different tunes for a while now, as I drive the car 75% of the time and need it to be stock for the other 25%. I was thinking something like;
#1- Just a 'tune up' of the factory engine settings, more of a fuel efficient setting with no gearbox changes.
#2- Higher state of tune for the streets (engine and gearbox data changes [when I'm in the car : ]).
#3- Full on street/strip setting (the best you can get out of the car).
The other plus is if the switch is in a positon without a tune, it acts like a kill swich (switch has to be hidden away obviously).
Here's what I'm refering to:
Danny, would this feature be available, and would it be possible to have the different states of tunes for the AU? How would you go about this set up wiring wise? Am I correct in guessing the other end of the cable to the switch (the chip) plugs into the ECU? No flasher box required?
"People can have the Model T in any colour.. so long as it's black." HENRY FORD (30/07/1863 - 07/04/1947)
PIC'S OF MY
T1 TS50.
12 is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2005, 08:47 PM   #54
Headsex
headsexTuned
Was supposed to have access to a dyno day, but its been changed till tuesday..
THE Ba Flash tuner from CAPa was 1300 originally i believe..
and now its 995.. With a "base tune"..
Custom tuning costs more obviously.
I imagine the AU will be priced the same as it will be using the same "hardware".
As for when ..... Not sure. Capa can answer this
Danny.
Old 09-10-2005, 04:29 AM   #55
FPVWEPN
Team Urinal Cake Racing
FPVWEPN's Avatar
ef-el's use eec-V would this product work on an ef 6 manual?
FPVWEPN is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2005, 11:40 AM   #56
Headsex
headsexTuned
Yes, the 4 position chip does work with the software. This does not mean E-Series cars will be supported at this stage. (Or possible, I dont know)
Old 09-10-2005, 11:42 AM   #57
Headsex
headsexTuned
The little circuit board plugs into the J3 connector of the ECU, and the wire / switch hangs out the bottom and placed in your location...
I am unsure if CAPA will be selling this or not.. You might need to ask.
Old 10-10-2005, 11:57 PM   #58
MaxPower
MaxPower's Avatar
Good news, I've spoken to CAPA and they have said this stuff will be available in 2 and a half months max. and Ive confirmed it will be the same price as the BA flash tuner $995 with basic tune,
__________________________________________________ _
14.59 AU1 XR8 Stock motor, custom cold air box, stage 2 shift kit in auto :
Engine rebuilt, match port, 621371 crow cam, double row valve springs, cromoly retainers, 30 thou pistons, larger valves, double row rollmaster timing chain, lots of machining n a flash tune after its ran in
MaxPower is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2005, 12:40 AM   #59
neil101
Cool I'll start saving now
Neil
HSV I JUST BEAT ONE!
03 XR6T lighting strike auto prem sound 19's
383.9rwkw
96 EF series 2 XR8 sedan manual
neil101 is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2005, 01:08 AM   #60
XRated
Shoot.
XRated's Avatar
Neil
I might start saving for an AU :
20V Turbo
