Old 21-02-2007, 09:12 AM   #31
StealthAu
Originally Posted by AU2PWR
What , so the Pipe will heat up and the air will stay cold ... Im Trying to be helpfull dude , it wont improve anything .. why do you think they come stock with the Pipe running away from the Enqine bay ? Its Becuase of millions of dollars of R&D tell them its the Coldest points of the Engine ,
but , Have a Go , Do a Pre Dyno Run and fit it , Re Dyno it , and let us know ,
Will hopefully have it fitted Friday, but either way I'll compair the 2 on the dyno this weekend.
Old 21-02-2007, 09:35 AM   #32
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
cool , let us know
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2007, 03:26 PM   #33
AU dude
Flying high...
AU dude's Avatar
Originally Posted by Norton
You do get the aluminium deflector as well, that's got to make it worh $200+... lol
i made my own deflector out of some mild steel which i found at work. i bent it into the right shape, sprayed it matt black and screwed it down behind the grille. effectively it deflects more air into the snorkel.
AU1 Forte - 17'' AU2 Tickford rims on all corners, Super low springs,
KYB shock absorbs + camber castor kit and a 3.45 LSD, Tickford snorkel,
3" mandrel intake, K&N pod in the box, Polished Rocker Cover.
AU dude is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2007, 05:56 PM   #34
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Scored on of these , but left it silver - Cheers Gaz
AU2PWR
Old 22-02-2007, 11:32 AM   #35
xr8ute
Back on the road
xr8ute's Avatar
So much heated debate, about something that makes so little difference on a std car.
Intake warz...LOL
If your seriously keen on proven intake performance mods, go no further than a G&D or Bluepower intake. If you just want a functional "shaker", then just do it....dont expect any difference in engine performance (just noise).
BTW, the i6 engines dont run a MAF at all... (they use a MAP)
Old 22-02-2007, 12:58 PM   #36
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Agreed , Cosmetic Purposes Only , it would Look ok , but your I6 wont gain much at all ..
Race Warz is cancelled , Intake Warz is on !
AU2PWR
Old 22-02-2007, 01:06 PM   #37
StealthAu
We'll see, I don't expect monsterous gains, but I do think its got to make a difference. Either way its something different. Just took it to the shop for a quote seeing that I'm laking in tools at the moment and cant get it booked in till late next week at the earliest. Not sure if I'll be putting it on the dyno tomorrow because I'm not sure what it will cost to get it fitted , so I might hang off on wasting money for now
Old 22-02-2007, 01:10 PM   #38
DEVL-XR
EBII XR6
DEVL-XR's Avatar
If theres so much heat coming off the rocker cover than why did the old school V8's, ie. XY GT's etc have the intake on top of the engine?
AU Dude: Looks good, do you notice much difference?
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2007, 01:19 PM   #39
xr8ute
Back on the road
xr8ute's Avatar
Because sex sells... i.e. it looks hot (and maybe they where just ignorant to the issue back then?)
Have a look at the real production-based touring cars at the end of the 70's, and early 80's. Most of them had some kind of shielding to get more cold air around the carb and/or deflect the hot air away under the car.
Old 22-02-2007, 01:32 PM   #40
StealthAu
well if heats such an issue, then maybe they should turn the manifold around so the throttle body isn't facing the engine
Old 23-02-2007, 04:31 AM   #41
AU dude
Flying high...
AU dude's Avatar
Well i installed the tickford snorkel and did the deflector mod at the same time. from stand still i didnt notice any difference, but at speed i did get a bit more throttle response when overtaking or kicking it down a gear, because thats when the deflector is most effective. drawing air from behind the grille and into the snorkel. i plan to get bigger intake piping and a pod in the box soon.
