#61 | |||
Oo\===/oO
Just like a Mustang embarrasses euro trash with its "outdated" rear suspension...
#62 | ||
I run both but i have the common sence to know which is better, nothing wrong with my windsor motor at all but if i could afford to replace them all with miami motors i would.
Look at the cosworth v8,its old but wow. Another factor overhead cams gives you is more than two valves per cylinder and true hemiphirical head designs. Again no one is bagging the old motors but it is 2010+ |
#63 | |||
#64 | ||
Mad Scientist!
This VVT on a aingle cam??
So how much variance will they have in comparison to a true vvt-Dohc? Looking forward to seeing this one |
#65 | |||
#66 | |||
Barra Turbo > V8
Im as blue as blue.
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+ -2022 Hyundai Tucson Highlander Diesel N Line |
#67 | |||
![]() iron block, iron heads, two valves baby combo.. i dont give a rats how it is done or what badge it wears in this world of down sizing.. air pump |
#68 | ||
![]() Join Date: Aug 2006
You would think that people would be happy that ANY petrol powered eight cylinder engines still exist in passenger vehicles in this day & age.....
I know I am. |
#69 | |||
Member
Forgive me (and the rest of us) for not being immature enough to bag out a motor that nobody has driven yet, on the basis that it uses pushrods and wears a GM badge. I've really got no time for this fanboy crap. And me, I have no idea why I'd be on a Ford forum. It might have something to do with the three FG Falcons I've purchased. I vote with my wallet. |
#70 | |||
true story |
#71 | ||
Now Fordless
Both have pros and cons. If GM can still keep it up to emission standard then they can do whatever they want.
#72 | ||
This pic should explain the main reason...
LS1 vs Nissan 3.5L V6 ![]()
#73 | |||
Now Fordless
#74 | |||
Peter Car
![]() So what happened to the 5.5, is that going to be a replacement for the 6 litre in the SS? This 6.2 will only replace the LS3 in the HSV's, what of the 6 litre's replacement? All Ford need to do to keep pace with HSV's new engines is to up boost pressure 0.5 psi ![]() At least in terms of badgework, we all know they are well past 335. |
#75 | ||
"Old fashioned" pushrod engines? Shorter engine, cheaper to build, lighter weight, less complexity, less to go wrong, easier to modify...
Nope, no idea why anyone would want to stick with pushrods... ![]() That picture of the LS1 sitting next to a "small capacity" V6 says it all... |
#76 | ||
#77 | ||
Look at the size difference between the 4.6 modular OHC and the Windsor...
#78 | |||
Straight Eight
This is exactly what GM wants for the Corvette. And seeing as they don't care what V8 power their other cars... they may as well use Pushrods too. If I had a Ford GT. I'd take out the OHC 5.4SC V8 they put in it... and drop in a worked Roush 7.0L pushrod alloy V8. Take it back to it's roots when won Le Mans.
The Falcon is dead. Long live the Mighty Falcon. |
#80 | ||
[QUOTE=Brazen]Look at the size difference between the 4.6 modular OHC and the Windsor...
![]() When you're talking about packaging, that's the difference, AUs an BAs were originally meant to take the 5.0, you could imagine the difficulties encountered by Ford having to find room in Falcon's engine bay for the Boss 5.4 Could you imagine a modern Windsor with VCT and DI, the packaging would be fantastic. |
#81 | ||
I’d suggest most seem to look at the photo on the front page of the article, see that it’s still a narrow engine with narrow heads so they know it’s still pushrod actuated and don’t bother reading anything else .. other than to quickly scan for the displacement so they can see if it’s bigger than OHC equivalents.
They forget there is actually a lot of technology and sophistication in these engines. They are not just an aluminium derivative of a 1955 265V8 with a computer bolted on. If you can produce the same power, torque and economy from simpler machinery (albeit larger capacity) .. who cares? |
#82 | ||
KISS theory?
#83 | |||
Barra Turbo > V8
#84 | |||
The Silver Bullet - BJ74 Where the actions at Ontrack 4wd Club https://www.facebook.com/ontrack4wdclub |
#85 | ||
Well buy a fricken ROTARY... NO CAMS!!!!
#86 | |||
#87 | |||
N/A Equivalent year engines. Ford 5.4L 290kw 53.70kw/L OHC Ford 4.0L 195kw 48.75kw/L OHC FPV 5.4L 315kw 58.33kw/L OHC HSV 6.2L 325kw 52.42 kw/L Pushrod GM 6.0L 270kw 45kw/L Pushrod GM 3.0L 190kw 63.33kw/L OHC GM 3.6L 210kw 58.33kw/L OHC FI Engines FPV 5.0L 335kw 67kw/L OHC Supercharged FPV 4.0L 310kw 77.5kw/L OHC Turbo GM LS9 6.2L 476kw 76.77kw/L Pushrod Supercharged GM LSA 6.2L 432kw 69.67kw/L Pushrod Supercharged Shelby GT500 486kw 83.79kw/L OHC Supercharged
#88 | |||||
Its a few factors but what about technology lol, the stone wheel evolved and that turned out ok. |
#89 | |||
If you look at a Chrysler Hemi V8 or Polysphere you'll see the valves opposed using weird and wonderful rocker arrangements to actuate them via pushrods. It's a easy to stretch to understand how the same rockers could be use to activate multiple valves. This thread has some interesting pix: http://forums.corral.net/forums/5-0-...ysler-did.html Last edited by OzJavelin; 26-10-2012 at 01:32 PM. Reason: Forgot to mention Honda CX500 .. |
#90 | ||
I'm sorry but there is only one OHC V8 that does it for me and it looks like this
![]() Other than that I will take pushrods anyday. |
