#181 | |||
You dig, we stick!
"....You don't put the car through engineering" - Rod Barrett. |
#182 | ||
Getting it done.....
Its really far to early to say much about the RWD version of this engine that would be in Falcon. I doubt Ford itself know/has decided on a final power output etc. Testing at this stage is all about torque/weight, driveability, installation/cooling and how this all works out versus fuel burn etc. As things move on NVH is further investigated and finally, marketing gets involved when deciding just how much grunt the motor will have (not to mention the number put on the badge....true or not).
As noted earlier money is on about 160-170kw, so to get from 147 to 160 would only take what Falc'man has aluded to (intake/exhaust etc.). I don't think Ford will want to go right up to 190kw etc., for starters because you would be pushing it a bit (which doesn't help fuel burn...mitsu evo 2.0T anyone...) but also because there is no need. The 0-100 times of FG falcons is certainly much better than my EF XR6 for example (it is packing more than 30kw more power), but its the modern DIVCT set up that gives it the improved driveability and makes it 'feel' so much quicker whe you drive it. Combined with a mondern 6sp i think a 340-350nm engine at 1500 rpm would feel just as punchy if not more than something like a AU VCT. It will be interesting how they market it as much as anything because with small capacity and two less pots than the Holden 'competitor' it could be an issue. Particularly if Ford does undershoot the power number a bit and come in some 20+kw less than Holden's 3.0 SIDI on peak power. Of course we know better, but the average punter might be fooled into thinking the Ford is a 'slug'. I would say the fuel economy angle will be used, given this thing is on track to burn low 8s.....
Dynamic White 1995 EF XR6 Auto Now with: Pacemaker 4499s Lukey Catback Exhaust Chrome BA XR-style tip Airdam Mounted CAI with modified (bellmouth) airbox Trip Computer install KYB shocks Bridgestone Adrenalin tyres Coming Soon: Exhaust Overhaul..... |
#183 | ||
Lukeyson
![]() Join Date: Mar 2005
I think a 'best of both worlds' dual PCM mapping is required these days. One to give the the car bragging rights for fuel efficiency in economy mode, and another to give it power bragging rights.
The processors inside the Spanish Oak PCM's used these days are more than capable of addressing additional off-chip flash. The Power button (aka shift-the-gearstick-left-to-perf-mode) should do more than just change the transmission shift strategy if you ask me..... Lukeyson
If the human brain was simple enough to understand, we'd be too simple to understand it. |
#184 | |||
An Economy switch that changes the tune !! |
#185 | |||
But on the other hand if you can just generate a tune that comes close to doing both why give people the option. For 'car people' it might be pretty cool, even used quite regularly but the average joe bloe won't really understand it or use it. Hell the 'sequential' option on autos has been around a while now and most people just put them in drive and potter around. Regardless of overtaking, cruising, round town etc. they just drive them in one setting. The 'econ' switch on EF-AU is the same...almost everyone drives around with it 'on' all the time except maybe towing or large hill work (or ahem...testing....). Maybe sport models it would make more sense (switchable ESP is common and aussie cars are taking it up now as well) where you might want to stretch her legs on occasion. But blatant 'detuning' is not the way to go to save fuel....for one it woud only work if the driver consciously did it and then DROVE ACCORDINGLY. If you put it in 'eco' mode then hit the gas hard repeatedly it will just burn as much if not more than before. If you castrate the car too far to save fuel you make a pretty horrid compromise and no one will use that eco mode anyway (which is what happened on the subarus which were pretty low on torque to start with). I'd rather manufacturers did their best to get a good base tune, then for perf cars maybe offer an 'agressive' mode that was linked to esp/auto etc. to get that hard edge in responsiveness. Basically take the 'supercar' and luxo set up and offer it on all cars. I suppose like everything this will happen in time. Either way the I4T eco engine in a falcon is no place for such options. The important thing is that is delivers what is needed in base form out of the box...which i am confident it will.
#186 | |||
Mad Scientist!
I don't think this'll work. To do this properly, FORD will have to dyno every engine to create a map for that particular engine due to small indifferences and tollerances in the engines. This would blow the costing's out of the water. If they made a generic map, i think you'd still find cars running rich and others pinging there head off. Maybe with the econ tune, this could be another OPTION when buying the car. If selected you get a copy of the Dyno sheet showing all the fully optimised infomation. ie/ A wnak really, they could also print the info on the engine ALA HSV power curves on the v8. |
#187 | |||
Guess Who's Back?
The 18th Letter |
#188 | ||
The Falcon is heavier, so say, still an impressive 8.4l/100km?
#189 | ||
Does any other car in the family car class, e.g. Accord, Maxima, Aurion have this type of technology coming? Falcon will be a very impressive package in 2011.
#190 | ||
I used to have a nice car
Would be nice to know what the engine weight of the Eco4 is. And also the dual clutch g/box. Anyone know the weight of the I6? The ZF box is 75kg on it's own.
#191 | ||
Thailand Specials
Reckon they'd include the new I4 EB in FWD with the same power/torque as the Falcon for an XR4T in the WS Fiesta? The car only weighs 1090kg, it would be pretty cool hey?
#192 | ||
Fiesta would probably get a 1.6T for the ST
#193 | |||
Theres atleast 100kg to be saved, if not closer to 150kg.
#194 | ||||
I said in this post: Quote:
Either way my points remain totally valid, not only based on this latest info but also the results of the 3.0 SIDI Holden V6....which continues to undeliver on its supposed fuel saving promise. As long as Ford can get an ADR number of less than 9/100km (which they will) while still having solid performance (i.e. like a real large car....not this Holden 3.0 V6 trollop) they are home marketing wise. Add a knock down of the camry ADR and backed by real world results and things are looking pretty good. Throw in the new coyote SC V8 and its a good time to be a Falcon fan no?
#195 | ||
I think they'd need to be at least 8.4l/100km so that the engine is viable with the extra premium cost and also the public perception of the bad reliability of turbos.
#196 | ||
I can't wait for this 4cyl Turbo engine to come out in the Falcon. If my stars are shining i'll get one into the Escort ASAP hehehe. Any version of the turbo engine will do me. Now that will be fun!
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery! Insta@mooneye_ghia White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly |
#197 | |||
Back to the S-Max, well it is detuned for 8.1L/100km and weighs 1600kg. It does have some cons though. The frontal area is large and the people mover body shape will not be as aerodynamically efficient as an FG Falcon. Together they mean a higher CDa figure. eg more drag. I reckon Ford Aus will be pushing like crazy for a 'psychological' number. That will either be 7.9L/100km or 8.3L/100 which undercuts the VE 3.0L by a full litre. That lower figure might take low rolling resistance tyres like the VE. Swordy, your estimate of 8.6L or better will be achieved. I'm sure of it.
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s 226.8rwkW@178kmh/537Nm@140kmh 1/9/2013 14.2@163kmh 23/10/2013 Boss349 built. Not yet run. Waiting on a shell. Retrotech thread http://www.fordforums.com.au/showthr...1363569&page=6 |
#198 | ||
Thailand Specials
I think the older folks are a bit weary of the whole 4 cylinder idea, my Dad commented on the 4 cyl Commodore and how bad it was. So already for some people it has a bad image.
But I look forward to it, I like going forwards in technology ![]() |
#199 | |||
Fordaholic
#200 | |||
If you have it tuned agressively and have I6-like grunt, it might burn 8.9-9.1....but why do that if you have an I6 that is around 9.6-9.8 by then anyway??? Not enough difference to convince the average punter to go for it. If you go for 7.9-8.1L/100km you would have to make it a real 'econetic' model....like a fiesta/focus econetic with special badging etc. If you aim to fit the engine in a range of falcon models as a 'option' engine etc. then you'd go middle of the road...so 8.3-8.6 and have more than adequate performance with a good litre or two per hundred REAL WORLD saving over the I6 (at least in urban driving...which most people do....). The rumours are pretty consistent that this is more than a 'one model' engine....but its not so clear if Ford will run different tunes for different models etc. There is no reason at all (apart from cost in developmet of course) why Ford can't have a 'econetic' style model that burns 0.3-0.5L/100km less than the others. A minor retune, low rolling resistance tyres, weight saving (less creature comforts then up spec models at least) etc.
#201 | |||
#202 | |||
Peter Car
#203 | |||
IWCMOGTVM Club Supporter
http://www.caradvice.com.au/64835/fo...le-for-falcon/
Daniel |
#204 | ||
How many Eco-boost mules are out and about? Only about 9 months away from release now!
#205 | |||
Cobblers!
Ego BFII Ghia Titanium Silver E53 X5 4.4i Gunmetal EF XR6. Now retired from active duty. Roses are red. Violets are blue. OS X rocks. Homage to you. |
#206 | |||
Walking with God
It's the minds and hearts of the younger ones we need to win over. I think it'll be a hit. GK
#207 | ||
They're out there alright, but most will not be able to pic them. Might even be running around in unexpected bodies.
#208 | |||
FORMERLY TX3DUDE
#209 | |||
Cobblers!
#210 | ||
Ghiadude might be closer to the mark...
