Old 20-05-2011, 11:24 PM   #1
Citwit
Default Oil Changes
Do most dealers do oil changes by removing the sump plug and draining the oil or do most remove the oil with a pump through the dip stick tube?
Citwit is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2011, 11:56 PM   #2
J.Molloy
Territorial
J.Molloy's Avatar
Default Re: Oil Changes
sump plug mate...
indiana pearl SX AWD Ghia
J.Molloy is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2011, 12:39 AM   #3
Neale
Neale's Avatar
Sump plug, thats what its there for.
Never herd of pumping it out via the dipstick tube.
Neale is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2011, 01:09 AM   #4
spedwards
spedwards's Avatar
I don't think it's overly common as in most cases you require access under the vehicle to switch the oil filter. While the car is up in the air you may as well empty from the sump plug.
Example on a Smart car, not sure why they would bother considering they had it up on the hoist for the filter though...
spedwards is offline   Reply With Quote Multi-Quote with this Post
