Old 13-05-2009, 07:01 PM   #1
R0BD0G
R0BD0G's Avatar
Default Escort Headlights Wattage bulbs etc
has anyone found a way to run brighter bulbs than a 40/45 in there standard escort mk1 headlight. ive been told it wont be sufficient to run a bulb that dull|?
1628 Escort Project Thread
67.3 RWHP - Paramount Performance Dyno
DJ Automotive Tuned with proper jets
http://fordforums.com.au/showthread....4&page=1&pp=25
R0BD0G is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2009, 08:41 PM   #2
75Cortina
75Cortina's Avatar
Hi,
Are you lights sealed beam?
The way I did it in my corty was to get new head lights that just took a standard H4 and H7 for the high beams, as my originals were seam beam units.
I changed the plugs over and soldered and heat shrunk the join and I never had a problem, from memory i ran crystal vision for the normal and some Arctic Blue for the highs and as i had the twin light set up my high beams were better then most new cars, and the normal beams were pretty good as well.
You should be able to get some replacement headlights that take the H4's from a Shop in the UK (sorry can't remember the name just now i was refered to it when i was looking for mine), or try rare spares; I ended up getting mine from Nepean Spares they just ordered them in as mine are just a common 5 and 1/4 inch enclosure.
Hops that helps.
BTW I’ve seen your build thread and your car looks awesome!
Current Project: Rebuilding my Corty!
220kw Au3 XR8 Engine, full Custom Zorst, EMS Computer, Underdrive pulleys and MSD coil Parks.
TKO Tremec 5 Speed
Full Floater 9in 31 Spine with locker
Its almost there!!!!
75Cortina is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2009, 08:56 PM   #3
R0BD0G
R0BD0G's Avatar
thanks. it has a replaceable twin filament bulb aswell as a park light in the housing. there is a guy on ebay selling a pair of headlights but doesnt mention anything about bulbs etc
Old 13-05-2009, 09:20 PM   #4
JamesR
put some proper relays in. that should help a lot, and take the strain off the headlight switch
1977 MkII Escort Ghia.
2006 MY07 Subaru Liberty GT Spec B wagon.
my photo blog;
http://www.jamesruff.net
JamesR is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2009, 09:46 PM   #5
R0BD0G
R0BD0G's Avatar
got a new era relay that will be fitted.. but brighter bulbs??
Old 14-05-2009, 07:04 PM   #6
JamesR
the relays should help with brightness, couldnt say how much though.
they'll help with a better more stable current.
my photo blog;
Old 14-05-2009, 07:54 PM   #7
R0BD0G
R0BD0G's Avatar
thanks
