Old 19-11-2016, 07:56 AM   #1
uncertainbrien
Default Aftermarket Stereo volume controls
Hi All,
appreciate any help.
I bought a joying head unit for my au3 station wagon. I installed it and it works fine.
https://www.carjoying.com/joying-aut...arema-679.html
I'm having trouble getting the steering volume buttons to work. The joying site is difficult to understand.
here it is: http://www.joying.ca/joying-blog/13.html
They have a key 1 and key 2 for volume up and down. I can't find a clear answer as to which wires on the harness I hook these up to.
Can anyone help?
uncertainbrien is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2016, 08:47 AM   #2
foxtrot3
foxtrot3's Avatar
Default Re: Aftermarket Stereo volume controls
Hi. The red/white wire in the factory harness is the steering wheel control wire and you need to connect it to "key1" and then program the set to work with the functions as required. Cheers MD
HI
I'M MICHAEL
foxtrot3 is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2016, 12:27 PM   #3
uncertainbrien
hi Michael,
i really appreciate the reply. I've looked at the factory plug/harness but can't see a red and white striped one.
I've taken a picture. I have a red and blue and a red with gray rings.
Am I missing something?
Ian
Old 19-11-2016, 12:33 PM   #4
uncertainbrien
sorry, here are the photos.
https://drive.google.com/open?id=1o9...9BfP0_XrE_k5mQ
https://drive.google.com/open?id=1mkvFQZB8rIypYZj16oDI-mkX5mINaELyB
Old 19-11-2016, 12:57 PM   #5
foxtrot3
foxtrot3's Avatar
Hi. Check the plugs at the steering column. Cheers MD
HI
I'M MICHAEL
Old 19-11-2016, 03:00 PM   #6
uncertainbrien
hi Michael,
thanks again for your time. Are you talking about removing the steering wheel or airbag?
Or do you just mean looking underneath at the plugs? If so, there are a lot of plugs under there.
Here are some pics.
https://drive.google.com/file/d/1EqF...ew?usp=sharing
https://drive.google.com/file/d/10LX...ew?usp=sharing
Old 19-11-2016, 04:40 PM   #7
foxtrot3
foxtrot3's Avatar
Hi. It will be in one of those plugs at the bottom of the column, a small 4 or 6 pin plug from memory. Dont cut the wire, just join another wire to it. Cheers MD
HI
I'M MICHAEL
Old 21-11-2016, 06:04 AM   #8
Fyrestorm
Spanner Thrower
In your photos its the blue w/ white trace one two to the right from the orange wire (although colour says its the red/ehite trace next to that. Odd) Not aure why your au3 has a different wiring colour setup to my au1 though, could of sworn theyd be the same.
1999 AU Futura Wagon (Nickname Betsie the Barge-***)
Current Mods: Fairmont Cluster, LED's Changed to Purple, Lukey Competition Extractors, 2.5" Hi flow Cat, Hi-Stall Converter, ED Box with FG internals, AUIII VCT Fuel Rail + Injectors, F6 Fuel Regulator, Stereo upgrade, Aftermarket LPG.
Awaiting Wife Approval Mods:
TE50 Front Bar, AU Tickford/SR Interior, Roof Racks, Slimline Weathershields, 2.5" Cat Back Exhaust, 27mm Front Sway Bar, Other Shiny things!
Fyrestorm is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2016, 12:36 PM   #9
Cav
HUGH JARSE
Cav's Avatar
This was connected to my AUII Fairlane witha Sony headunit.
Volume and seek on Ford controls work fine on USB and FM
http://www.pac-audio.com/productDeta...ProductId=1016
Cav is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2016, 11:30 AM   #10
TOP DOG
TOP DOG's Avatar
Do you have any pics of the stereo fitted into the car?
I would love to see how the big screen looks.
Thanks.
Graham
South of DARWIN NT
AUIII Flash Cab project (nearing completion)
TOP DOG is offline   Reply With Quote Multi-Quote with this Post
