Can u get shortened struts For front of an Au?? if so who makes em? price? i have superlows all round but need it lower in the front cos i have a bit of weight out back in boot, with a full tank load it feels like a driving up a little hill and the front sits high.. thanks.
Miami Pilot
![]() Join Date: Jan 2005
The springs are what determines height, though there are theories around that the shortened shocks may also help, but I don't think that's necessarily right. Easy way to tell if they will do anything is to compress a standard shock all the way in and see how much of the shaft sticks out of the shock casing. Then have a look at the shock fitted and if there's only that amount of shaft sticking out, then a shortened shock will reduce ride height, otherwise, it will not. IMO, perhaps only the rear shocks on an IRS equipped vehicle would even come close to achieving this.
Best bet is to ring a suspension place. I know Monroe DON'T do a shortened shock, but Koni do, and I'd bet that Bilstein would as well - both dearer brands.
if something could hold the springs a little lower in the cup that would be great..
FYI, Monroe do a shortened shock, i had them in my au II xr6 untill i replaced them with konis. if anyone in melbourne wants them for a small price, let me know. Also, i dont believe that shocks should change the height of the vehicle, but when i changed to the koni setup (still using the same springs) my car is definately a little higher at the front.
so u have front shortened struts for sale?? i know the shocks wont change the height of the vehicle but having the spring sit lower in the shock cup will which is what i want. this seems like to much stuffing around im steering towards coilovers now
#6 | |||
Best AU body kit - NONE
T3/Sprint8
and known a SenselessTrac in the suspension game. Friggin crap.
Monroe only have part numbers suitable for FE2 XR etc nothing for a proper 25-50mm lowered set up. Ppl use them cause of price and it's Russian roulette if they last or not.
heres a link for suspension adjustable struts and stuff , good for a lookhttp://www.fulcrumsuspensions.com.au...bout_tein.html
big kel
hi mik pedders no bull ...
#10 | |||
Life's a Gas
You can normally look at Munroe's catalogue through their web site at www.munroe.com.au, but the site has been down for the past couple of days. There are definitely two versions of both Sensatracs and GTs. |
Yes the monroe range do a short shock for the REAR ONLY. But the front is standard height, there is no short option. The part numbers are the same.
Anyone had experience with sensatrac before, good or crap anyone???? |
#12 | ||
PM me if you want
I got Gabriel lowered front shocks for my EA, made my lows sit just a tad lower, very happy with them so far.
Owner of first ever car to retrofit BA SSS - the EA2BA Send me a PM if you want to know anything 2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
#13 | ||
u have a E series u can get anything for em, u have to spend a arm and leg on Au its crap. Im over it can stay how it is for now.
#14 | ||
Noddy is looking into a group buy on Bilstein at the moment.
http://www.fordforums.com.au/showthread.php?t=76059
#15 | ||
yeah i was looking at that
#16 | ||
Audi S3
get out the angle grinder and cut half a coil off the front springs :hihi: will lower it ~15mm
#17 | |||
Life's a Gas
Here are the Monro part numbers for AUII. I've marked the ones that are different from standard height with ***. Sedans - Standard Height Front - GT Gas: 35-0447 - Sensatrac: 37-0447 Rear With IRS - GT Gas: 35-0449 - Sensatrac: 37-0449 Rear – Beam Axle - Gas Riser: MGR-109 - GT Gas: 15-0202 - Sensatrac: 17-0202 Sedans - Lowered ("S pack"s or equivalent) Front - GT Gas: 35-0447 - Sensatrac: 37-4447 *** Rear With IRS - GT Gas: 35-4449 *** - Sensatrac: 37-4449 *** Rear – Beam Axle - Gas Riser: MGR-109 - GT Gas: 15-0202 - Sensatrac: 17-4202 *** Sedans - TICKFORD Front - GT Gas: 35-0447 - Sensatrac: 37-4447 *** Rear With IRS - GT Gas: 35-4449 *** - Sensatrac: 37-4449 *** I bought 35-0447 (Fronts) and 37-4449 (Rears). |
#18 | ||
can u post up a pic of your car abacus?
#19 | |||
Life's a Gas
The before photo, taken while it was on super lows, is here: http://i32.photobucket.com/albums/d4...SideView-2.jpg It looks noticeablly higher now, it went up from 635-640 all round to about 675 onthe back and 670 on the front. I expect it to settle down a bit, particularly when the LPG tank goes in next week. |
