Old 30-03-2005, 04:24 PM   #1
montEL
Default Wtf
Hi Guys,
I was driving today(about a half hour drive) in my EL Fairmont when suddenly the Cruise switched off, I looked down at the Speedo to see that it had Zero'd out. I noticed the engine was reving a bit hard, as a check i pull the shifter back into thrid, sure enough no change in engine RPM. I had lost 4td gear, the car had jumped back to third and wouldn't shift up into 4th again. In about a minute it had all come back only to drop out again in another few minutes. After getting to my destination and letting the car sit, I drove home. Not a a problem all the way home. Does any one have any ideas?
I was thinking it could just be a speedo sender unit getting ready to die, but I can't explain why 4th disapeared. Can anyone shed some light on the situation?
Regards,
MontEL
Old 30-03-2005, 04:27 PM   #2
neb
hibernating
neb's Avatar
could of gone into limp home mode? my old auto did something like that a couple of times where it only had 3rd gear... all i did was turn the car off and then start back up again and it was fine.
neb is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2005, 04:27 PM   #3
EFFalcon
Last warning
EFFalcon's Avatar
possibly the trans went into limp home mode due to having no speedo input (had no idea what it was doing)
if the transmission goes into limp home mode, it stays in 3rd gear.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 30-03-2005, 05:05 PM   #4
Au2falcons
Winter all year round
Yes if the the speedo transducer (speed sensor), isn't working then it will go into limp mode and get stuck in third. I assume that would stop the cruise from working aswell. My AU did the same thing though, my transducer died totally.
Cheers,
Adrian.
Some people drive sports cars on the weekend....I drive my AU! It's not what you drive...it's how you enjoy it.
Recommend trading with Mechan1k, Offyaguts, EDMONTY, PhantomXR8, HOTC2R, Partie & JC
Au2falcons is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2005, 05:31 PM   #5
Smoked
Burnin Rubber
Smoked's Avatar
Agree with everyone else, limp home mode for sure. Think your speed sender unit needs replacing.
2001 AUII Forte (LPG)
K&N Air Filter
Tickford Air Intake
***Coming Soon: Clear Side Repeaters***
Originally Posted by The-ShowStoPPa
...dont get me wrong this 3.8v6 is pretty special, it does come with the popular shake rattle and roll option and the auto compliments this with the ever popular snap crackle and pop feature
Smoked is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2005, 05:54 PM   #6
RED_EL_XR8
RED_EL_XR8's Avatar
Spped sensor or was a recall in EF/early EL 6 for a harness connector problem with wiring going O/C from heat of exhaust.
RED_EL_XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2005, 09:49 PM   #7
montEL
Thanks all for the responses.
I imagine if I get a new speed sensor fitted, it would be the updated part? and it should all be good?
Old 30-03-2005, 09:57 PM   #8
*rayman*
454 Power
*rayman*'s Avatar
hence the ford ad that used to be on 'he must be stuck in third eh?'
DAILY - 00 75th Anniversary Futura
TOY - 68 SS 454 Camaro
*rayman* is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2005, 08:02 AM   #9
EFFalcon
Last warning
EFFalcon's Avatar
Bhwahahaha
secret meanings ;)
montEL: yeah i imagine the part that gets fitted will be fine, i have no idea if mine was replaced, but i've never had an issue.
Old 31-03-2005, 12:52 PM   #10
bindi
Redhead extraordinaire...
bindi's Avatar
Ah so, a secret meaning? lol that's cool.
I love the new ad "Incredible pulling power" bwahahahahahaha They are damn straight about that one hehehe
Bindi
88 EA- his car
88 Rolla - MY car
Originally Posted by big_waity
Oh, and another surefire symptom will be the Falcon badge at the back.
bindi is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2005, 03:48 AM   #11
jjj
jjj's Avatar
The problem could be in the wiring harness??? I recently spoke to a very experienced auto electrician and he said alot of the ford wiring looms aren't rated for the current they are carrying. Seen it on brake lights where the wire burns out or becomes high resistance. Also try spraying the connectors on the gearbox with a bit of contact cleaner.
Cheers Luke..
EL FAIRMONT
Pacemaker 4499's
Megaflow 2.5in Cat
X-Force 2.5in Sports Exhaust
Champion STEEL igntion leads
K&N panel filter, EL GT Snorkel, modified airbox
16in Speedy Holotype-R mags on 225 tyres
jjj is offline   Reply With Quote Multi-Quote with this Post
