Old 20-12-2006, 06:03 PM   #1
Sapper
Back to the AU
Sapper's Avatar
Default AU Ignition Wiring Diagram
Does anyone know where I can get a wiring diagram for the AU I6 EDIS? So far I've checked the wiring diagrams and technical resources of AFF.com.au, the technical documents of FordMods and done a search, all with no results. Closest I've come is this , but it doesn't have an actual wiring diagram.
To answer the likely questions, I'm looking for this so I can look at ways of optimising my ignition. I'm doing this to help with future performance gains and to try and solve some starting issues (yes, I've changed plugs and am currently checking the fuel delivery system).
If someone was a wiring digram of the EECV as well, that would be awesome, but not as critical at the moment.
Thanks in advance,
Matt
2001 Ford AUIII Falcon XR8 Manual - Can't get enough of the AU
2001 VW Bora V6 4Motion - If I squint it almost looks like a Sierra Cosworth
Sapper is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2006, 07:40 PM   #2
EvilChief
Boost Addict
i can tell you what pin on the ecu is doing what, if u let me know what u r after.
I am a little puzzled on how u wanna optimise ur ignition? the only way to do that s with an aftermakret controller.
For ur information EF an AU use a motronic style sensor pickup on the crankshaft. 36 teeth with 1 (sometimes 2) teeth missing at home position (visially check for missing teeth to confirm). Ignition offset is 10 degrees.
EF also uses a "cam" angle sensor pickup, which is located in the dizzy whole, which is a hall effect sensors, which is used for home position signal only. if u use an aftermarket ecu, the motronic sensor will be suffice for pickup only.
If u have any forther questions PM me or send me an email to enquiries@sjwperformance.com
Mic
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2006, 04:13 PM   #3
Sapper
Back to the AU
Sapper's Avatar
Thanks evilchief. My dad's an electronics engineer and I'm and engineering student. We're just looking at the ignition on my car to see what condition it is in and make some modifications to improve its performance. We may go to an aftermarket controller if it is deemed appropriate.
Old 21-12-2006, 09:08 PM   #4
EvilChief
Boost Addict
no dramas just PM me if u have any more questions
N12 Pulsar - sold
