Old 20-12-2006, 03:10 PM   #1
Brent
Default High Quality Car Covers?
Hi all.
I'm fortunate enough to be able to garage my BOSS BF, but there seems to be sufficient airflow to ensure that within a day or so after cleaning the car has a layer of dust and soot etc from the air & roof area of the garage.
So, does anybody know of a brand of car cover that's designed purely as a dust cover, and that isn't going to sctatch the hell out of black duco whilst slipping it on and off? I don't mind paying good $$$ if its a good one, just not a cheapie.
Thanks.
Brent.
Brent is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2006, 08:56 PM   #2
Green X
How long are you going to be garaging it for, as other Preparation steps may need to be taken?
or are you simply parking it overnight and just want to put a car cover on it to keep it clean?
If the second one I would be more included to rent a Industrial vacuum for the day and climb into the ceiling and vacuum it out and fill any holes that are there at the same time.
But if you still want 2 do the car cover thing, then get a good qualit one and not a plastic one, Easy rely spend some $$ and you will get a good quality one, go cheap and you will just get chit.
Also I wouldn’t put a car cover on dirty paint.
Green X is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2006, 08:41 AM   #3
Brent
Its a weekend car. Gets garaged during the working week, then comes out to play for the weekends. Its an old garage with a pretty high corrugated iron pitched roof, so lots of airflow comes in under the roof lining etc, thus causing dust to come in. The cover would really only serve the purpose of keeping the dust off it for about 5 days per week.
Old 21-12-2006, 08:57 AM   #4
Polyal
The 'Stihl' Man
Polyal's Avatar
couldn't you just put a bed sheet over it?
A little ghetto I know, but if its only for during the week then who cares, plus it gives you an excuse to wash it every weekend.
  • 2017 Toyota Prado (work hack)
  • 2017 Mitsubishi Pajero Sport
  • 2003 CL7 Honda Accord Euro R (JDM) - K20A 6MT
  • 1999 Lexus IS200 - 1G-FE Turbo 6MT
  • 1973 ZF Ford Fairlane
Old 21-12-2006, 10:11 AM   #5
Bax
Projecting
I'm with polyal, bed sheet would be the best, the top of the line car covers with the soft fabric underside usually have breathers that allow air in, so if its breezey enough the dust will come straight through, I'd be tempted to leave it sit and then wash the dust off at the end of the week.
I just dont like car covers whatsoever
Bax is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2006, 10:49 AM   #6
gregaust
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Greg always goes out of his way to provide assistance and support to members of AFF. Greg freely shares his knowledge with people who ask for help and often assists them with obtaining parts and repairs.  A great member of the AFF community. Technical Contributor: For members who share their technical expertise. - Issue reason: Always happy to offer assistance from his own experiences and often posts up photos when someone is having issues finding/locating something they are trying to repair or replace.
I got a nice cover from autobarn with a soft lining in it.Around $120 for X-LGE.I can check the brand for you if that's what you're after.
gregaust is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2006, 11:41 AM   #7
XR Martin
XR Martin's Avatar
This is what you want. An inflatable car capsule
http://www.rdent.com/pages/carcap.html
2004 BA wagon RTV project.
Old 21-12-2006, 01:05 PM   #8
MarkAW
Brent
I own a garage with a similar roof type. My garage is used for wood projects which usually require dozens of lacquer coats. In the end I found it more worthwhile to seal up the roof than try to stop the debris from falling down.
For the eaves I had some sheet colour bond (150 x 3000) made and nailed to the rafter ends - between the gutter and wall. For the ridge cap I just used expending poly foam to fill the gaps.
__________________________
They call it a rort when they're not in on it
Mark
MarkAW is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2006, 01:50 PM   #9
Brent
Thanks Mark.
Yeah, it looks like I might have to do a bit of work to put some sheeting/wood linings around the gaps. The expanding foam filler sounds like a good idea as well for the roof area.
Old 21-12-2006, 02:11 PM   #10
Bill_R
Bill_R's Avatar
Seen that one - It's a riot! But it probably makes good sense to someone with too much money, a car collection and white polished marble floors in the garage. Or to someone with an auto-immune disease or Obsessive-Compulsive cleaning disorder.
Bill_R is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2006, 04:53 PM   #11
MarkAW
Best part was I stopped the ********* Indian Minors (birds) from nesting in the roller door.
Mark
Old 21-12-2006, 09:17 PM   #12
Silver Ghia
Silver Ghia's Avatar
In my old house I had the problem with the corrugated iron roof letting the leaves and dust in all over my car restoration project.
I got a roofing contractor to remove the roof iron, put Sisalation (silver coated paper) over the roof, ensuring the centre part and edges of the roof are sealed, then replace the iron with roofing screws.
This worked a treat, and also kept the garage a bit cooler in the hot weather.
Silver Ghia is online now   Reply With Quote Multi-Quote with this Post
Old 21-12-2006, 10:06 PM   #13
BlackBa
BlackBa's Avatar
Chuck a cheapo false ceiling in it!
BlackBa is offline   Reply With Quote Multi-Quote with this Post
