Old 15-01-2007, 12:09 PM   #1
jedaa
Jedaa
jedaa's Avatar
Default Ea Ghia Air Suspension Help
I just bought a ea ghia with air suspension does
any one know anything about this how do u tell
if it is working . I only stumbled upon it on ebay
looking for parts for car I see a lot of needs air
suspension fixed etc.
Can u still lower ghia with king springs low etc.
I can not find anything on net in aussie about
ea eb ghia air suspension.
Thanks Paul.
jedaa is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2007, 12:20 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
I have SLS, mine still works (One of the few).
1. Does it have the fuse for SLS in the fuse panel
If it does then it would beep if it doesnt work otherwise it's been removed and standard shocks/springs put in.
I have reset my SLS to low height and have king low front springs in my EA Ghia.
Old 15-01-2007, 01:16 PM   #3
EA Ghia
EA Ghia's Avatar
Air suspension was only with the Fairmont Ghia's yeh?
I'm pretty sure all it does is levels out your car when the rear end is weighed down (by a trailer or whatever). One way to see if your car has it, is to weigh down the boot with something (people?), and start the car. If you hear a weird whining noise and the rear end raises, it means you have the air suspension.
My car has had them removed, a pretty pointless aspect if you ask me, especially if you want to lower your car. I'm pretty sure that if you want lowered springs, you'd want to swap your shockers over as well (don't quote me on this though).
As for maintenance, I'd imagine that it would need regular service. I'd recommend you just put normal shockers in.
EA Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2007, 07:39 PM   #4
Clarke AV
OzECruisers Treasurer
Clarke AV's Avatar
air suspension Wow
Clarke AV is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2007, 07:46 PM   #5
Dezza
Parts bin special
Dezza's Avatar
I still have my SLS, and the sound the compressor makes is quite loud. I want to get rid of it though. It's simply way too soft.
Weekender 1964 US Falcon Futura convertible - Rangoon Red
260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels
https://fordforums.com.au/showthread.php?t=11470868
Daily 2014 SZII Territory diesel - basic runabout
Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more
2000 AUII Fairmont - XR wheels, Ghia interior
2010 FG XR50T ute - XR8 bonnet, Streetfighter intake
Dezza is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2007, 07:55 PM   #6
mark_TD
XR6 Turbo FTW
mark_TD's Avatar
You can hear the compressor noise when you put on the ignition, it means you have SLS, but they are a pain as they stuff up very easy especially when towing. I had it in both of my EA Ghia, and DF LTD and the EA stuffed up the first time I towed and the LTD just driving. You will know when it is not working if "Check Suspension" comes up on the dash and the warning of the clock beeps. Note the compressor could still be pumping when it is not working. Thats because usally the air bag shockers burst or something and doesn't pump. So if the compressor is pumping and the car doesn't rise, it mean the shockers have burst. SLS is a light duty suspension and are not recommended for towing.
02 BA XR6 T U R B O - 232rwkw @ 6psi
Blueprint, 19" FG2 XR6 Luxo Rims, Momo Steering Wheel, XR8 Bonnet Buldge, Full Leather, 3.7 Typhoon Diff Gears, Force Lip Spoiler, De-badged, Ghia Boot Garnish, Pedders Adjustable Coil- Overs And Camber Kit
96 EL XR6 - (Daily)
Gunmetal Grey, 19" Typhoon Copies, Tickford Body Kit, Pedders Sports Ryders With Shortened Shocks And Camber Kit, Full S/S Difilipo Exhaust With Matching Extractors
mark_TD is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2007, 09:55 PM   #7
I disagree; in fact I understand it was primarily designed for towing so the car stayed level when a Caravan pr similar was attached. I still have mine working in both my Fairlanes. It is essentially just an air adjustable shock absorber system with a computer module on the chassis joined by a link to the diff that senses the ride height and pumps up or deflates the shockies accordingly.
aussiblue is online now   Reply With Quote Multi-Quote with this Post
Old 16-01-2007, 01:08 AM   #8
blownba
LPG Forum Moderator
blownba's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For all his assistance helping members with their LPG issues.
Where are ya jedaa? If your in the eastern Subs. of Melb. I can help ya out as I know these systems inside out and know many tricks to get them going good cheaply using non gen parts and you can modify them to run in alowered position without ruining them.
blownba is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2007, 02:28 PM   #9
RayH
Blownba, what's the trick for fixing the leaking compressor outlet valve on the top of the compressor? (The one with the rubber plunger and the spring.
Regards, Ray.
NFV8
RayH is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 12:10 AM   #10
blownba
LPG Forum Moderator
blownba's Avatar
The biggest thing is making sure that the tube is in good condition. If its sqaushed or grooved cut a little bit off and then make sure that the outlet clamp is spotless, no dirt and **** in there. It usally comes down to the plastic tube in most cases like I said cut a piece off and get a perfect end. Alot of the pressure line stuff can be bought from companies that make production line equipment or even total tool sell alot of stuff in their air compressor range.
