Old 17-01-2007, 08:29 PM   #1
StookEB
Default Question about auto gearbox
My sister and I recently drove over to armidale (about 3.5 hours away). The majority of the trip is just cruising, but about 30-45 minutes of the trip you go over a major hill. The car is a EB 6cyl, the auto has very smooth gear changes, like our BA, when manually changing gears its smooth and when cruising on the highway it kicks down a gear.
But when under load such as going up a hill it slows down and the only point the engine will rev is flat to the floor ( with 7/8 of the pedal distance doing nothing).
Why don't these gearboxes like changing under load, a couple of my mates parents cars are like this too? You can feel the engine has power but it doesn't put it too the ground.
We had a removal truck infront on the way back and it was only going
10 km/h down the hill. I had to put it back to first and ride the brakes which was weird lol!!
Now driving an unbreakable Hilux, which is becoming full of rust :
StookEB is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 08:31 PM   #2
naughtyfalcon
not sure..sorry
2000 AU Wagon
naughtyfalcon is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 08:57 PM   #3
mark_TD
XR6 Turbo FTW
mark_TD's Avatar
Need a winsor 5 ltr
02 BA XR6 T U R B O - 232rwkw @ 6psi
Blueprint, 19" FG2 XR6 Luxo Rims, Momo Steering Wheel, XR8 Bonnet Buldge, Full Leather, 3.7 Typhoon Diff Gears, Force Lip Spoiler, De-badged, Ghia Boot Garnish, Pedders Adjustable Coil- Overs And Camber Kit
96 EL XR6 - (Daily)
Gunmetal Grey, 19" Typhoon Copies, Tickford Body Kit, Pedders Sports Ryders With Shortened Shocks And Camber Kit, Full S/S Difilipo Exhaust With Matching Extractors
mark_TD is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 09:02 PM   #4
Damo
some very useful posts so far. Go Team! Are you sure your accelerator cable isn't faulty ? That would explain the kick down problem.
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 09:13 PM   #5
smally289
growing up is optional
smally289's Avatar
Check the throttle cable for cracks, this normally happens where it passes over the rocker cover and may prevent you from getting full throttle.
My ED had a lousy kickdown IMO at highway speeds. To help this I used to engage power mode. Give it a try.
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 10:43 PM   #6
Ozfords
Girls! Drink! ****! ****!
Ozfords's Avatar
It is recommended to engage Power when; non-stop go-stop driving ie Taxi or Police car, towing or carrying a large load, overtaking and going up steep inclines.
Automatic Driver and I'd be proud of that fact, only if I weren't so lazy.
1993 ED Fairmont Sedan - I6 - Colbalt Blue
- XH Snorkel
- Superlow Kings Springs and KYB Shocks
- Cross Drilled and Slotted DBA front Discs
- 18" pre-AU GT-P Alloy Wheels
- Ford Original Bootlid Spoiler
Ozfords is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 11:23 PM   #7
Bill_R
Bill_R's Avatar
There is some diagnostic stuff here if you want to look: http://autorepair.about.com/cs/troub...a072702a_3.htm
Bill_R is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2007, 10:41 AM   #8
How long since the bands have been adjusted?
aussiblue is online now   Reply With Quote Multi-Quote with this Post
Old 18-01-2007, 01:59 PM   #9
StookEB
thanks guys, the next time I'm allowed near her car i'll check the cable.
I will kick down most of the time but not always. I think the box may only last a year or so, it has smooth changes though.
Old 18-01-2007, 02:12 PM   #10
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
mmm sounds like it needs a manual convertion, i think thats all you can do, mmm yes manual,
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2007, 02:34 PM   #11
Walkinshaw
Two > One
Walkinshaw's Avatar
Run a KOER/KOEO test and pull the codes for the ECU, chances are your TPS may be out of range etc
Old 18-01-2007, 04:27 PM   #12
Dezza
Parts bin special
Dezza's Avatar
LOL, that was my solution to my auto problems
Weekender 1964 US Falcon Futura convertible - Rangoon Red
260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels
https://fordforums.com.au/showthread.php?t=11470868
Daily 2014 SZII Territory diesel - basic runabout
Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more
2000 AUII Fairmont - XR wheels, Ghia interior
2010 FG XR50T ute - XR8 bonnet, Streetfighter intake
Dezza is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2007, 11:22 PM   #13
hako
hako's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Regularly gives valued, considered advice to others.
Sometimes with electronic transmissions kickdown will happen sooner if you floor the pedal instantly or release then floor. Remember that you are talking to a computer and it is programmed to figure out what you want. A slowly heavier pedal just means you want to go faster (the computer will maintain that gear for economy) but a instant heavier pedal means you want power and give me the max....so she kicks back a gear.
Thats the way I see it.
hako is offline   Reply With Quote Multi-Quote with this Post
