Old 07-04-2005, 07:54 PM   #1
ScoopED
Thumbs up for fossil fuel
ScoopED's Avatar
Default Looking for someone in particular....
G'day,
I am at the "no engine in the engine bay" stage of my 351W in to EB falcon conversion, and am in need of some advice from people who have done this conversion before.
I have not been able to track anyone down and was just wondering if anyone here knows someone who has done this and can put me on to them (or them on to me).
As far as I know there are only a few cars in the country which have had this conversion so it makes it kind of hard......
Any help would be GREATLY appreciated.
Thanks a lot,
Mike
God created F-trucks so that you could put their engines into E series.
1992 EB Fairmont
351cu in Windsor Roller Cam
Valve Body "Shift Kitted" BTR 4spd Auto
Hi Tek Headers Tri Y
Twin 2.25 into Single 2.5in
17in x 8in BA XR8 Copies
235x45x17 Nankang NSII
Ultra Low King springs
Whiteline 30mm Swaybar
Nolathane box section trailing arms
Slotted DBA front rotors
Yella Terra roller rockers
ScoopED is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2005, 08:01 PM   #2
ScoopED
ScoopED's Avatar
Sorry if this thread is in the wrong area!!!!
I just read the thread relating to that.....
Please move it if I have posted it wrong....
Sorry used:
1992 EB Fairmont
Old 07-04-2005, 08:08 PM   #3
LUXO_8
windsor user
what sort of info are you after??? (mainly replying to sign up to this thread...)
Old 07-04-2005, 08:16 PM   #4
ScoopED
ScoopED's Avatar
He he, Fair enough......
I need to know which extractors they used and which sump they used.
Also engine mounts, crossmember and other little bits and pieces..... problems etc
Mike
1992 EB Fairmont
Old 07-04-2005, 08:19 PM   #5
LUXO_8
windsor user
ah yep, im superly intrigued with your project, i cannot wait to see it finished...
Old 07-04-2005, 08:23 PM   #6
ScoopED
ScoopED's Avatar
Believe me, I cant wait to see it when its finished either......
I'll be a very happy man when that day comes!!!
It will be interesting.......... I mean no massive power, but still interesting.
Mike
1992 EB Fairmont
Old 07-04-2005, 08:34 PM   #7
trick_xd
I build your wish list...
trick_xd's Avatar
Hey scoop i had a 351 clevo in my ea and i know of another guy who did the same thing if your motor is the same ( i think it is ) then most will fall into place i used the same 6cl 5 speed out of the same car couse the starter hits the steering and had to lower the engine mounts 40mm . i used standard exhaust that was all i could to get it to fit
and a o.m.v.l. gas kit it was ok but the clutch sliped all the time and i was to cheap to get a V8 box and clutch
If it weren’t for physics and the law enforcement, I’d be unstoppable.
trick_xd is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2005, 08:45 PM   #8
LUXO_8
windsor user
nah he's using an injected 351 windsor from an early 90's F150
Old 12-04-2005, 08:23 PM   #9
ScoopED
ScoopED's Avatar
Thats right MADNC_8, its 5.8 Windsor roller.
So im guessing that no one knows anybody who has done the same swap as me?
Mike
1992 EB Fairmont
Old 12-04-2005, 08:32 PM   #10
needfordspeed
Ask Racecraft, I THINK he done something similar.
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH
needfordspeed is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2005, 01:19 AM   #11
XRated
Shoot.
XRated's Avatar
IIRC that was a Clevo?
20V Turbo
XRated is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2005, 08:54 AM   #12
LTDHO
The one and only
LTDHO's Avatar
You may find it hard to find someone as it's not a mod that been done alot. You will find that a custom sump and extractor will need to be made.
You will have to fit the block with heads and the get it measured or the items made on the car.
1992 DC LTDHO 360rwkw built by me
Tuned by CVE Performance
Going of the rails on a crazy train
Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
LTDHO is offline   Reply With Quote Multi-Quote with this Post
