Old 25-02-2007, 11:19 AM   #1
burkie_21
wild xr8
burkie_21's Avatar
Default 3.55 lsd diff for el
hey guys, i'm having a bit oftrouble locating 3.55 lsd diff gears for a series 1 xr8. can find plenty shorter but i do a bit of highway driving. needs to be strong as needs to handle about 210 at the wheels. any help appreciated.
burkie_21 is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2007, 11:28 AM   #2
bentles
bentles's Avatar
try finding 3.45 maybe? i dont think 3.55 exists i might be wrong however
bentles is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2007, 11:35 AM   #3
burkie_21
wild xr8
burkie_21's Avatar
was thinking the same but even trying to source the series 2 is hard enough. was looking somewhere round that ratio cos im running a crane cam which is the same cam out of the brute ute's, reccomends no less than 3.5 for optimal performance. didnt know diff settings had anything to do with the cam
Old 25-02-2007, 11:39 AM   #4
bentles
bentles's Avatar
the ratio of diff affects ur rpm at whatever speed the cam also gives power at certain rpm. my 1636 gives power from 3500+ so a 3.45 in mine would make me have +200rpm at whatever speed im doing, so if im doing 20, ill get to my 3400 sooner than later and the cam performs better id think...
maybe get a set of 3.88 maybe? just try ebay
Old 25-02-2007, 11:44 AM   #5
burkie_21
wild xr8
burkie_21's Avatar
thanks that clears a bit up, makes a lot more sense when u describe it like that
Old 25-02-2007, 12:08 PM   #6
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
series one diff gears are 3.23, only series 2 got 3.45.
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2007, 12:11 PM   #7
burkie_21
wild xr8
burkie_21's Avatar
yeah thats why i'm chasin shorter than the series 2. mine is the series 1 with the 3.23
Old 26-02-2007, 06:38 AM   #8
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
be a big man and step upto 3.9 gears
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2007, 06:28 PM   #9
mcflux
mcflux's Avatar
burkie, do you have a T5 or BTR?
The available (shorter) diff ratio setups for your diff include:
3.45
3.7
3.9
4.11
To obtain the RPM at 100kph, first divide your current RPM@100 by your current diff ratio, then multiply this number by the new diff ratio.
IE for me it was [1800rpm / 3.27] * 4.11
= ~2250rpm
I wouldn't bother with 3.23 --> 3.45 if I were you, you'll hardly notice the difference.
Old 26-02-2007, 08:26 PM   #10
burkie_21
wild xr8
burkie_21's Avatar
thats damn handy, thought it would make more rpm at 100. jus the standard speed. will be strengthened soon
Old 26-02-2007, 09:55 PM   #11
mcflux
mcflux's Avatar
no probs ;) It's one of my most common posts :P
Old 26-02-2007, 10:20 PM   #12
prydey
Rob
prydey's Avatar
i have 3.9's with auto (which has taller overdrive than manual - .68 v .72) and mine is revving closer to 2400rpm at 100km/h
prydey is online now   Reply With Quote Multi-Quote with this Post
Old 26-02-2007, 11:17 PM   #13
mcflux
mcflux's Avatar
But do you have a six?
Old 27-02-2007, 02:47 PM   #14
prydey
Rob
prydey's Avatar
no my eb is v8.
before that i had a ef xr6 5sp and that was at 2150 @ 100 with 3.45 diff. speedo was accurate as checked it many times during interstate trips.
Old 27-02-2007, 06:11 PM   #15
mcflux
mcflux's Avatar
hmm that's odd
although I think I may have discussed this with you on FM ages ago and we agreed to disagree?
Old 27-02-2007, 06:17 PM   #16
prydey
Rob
prydey's Avatar
yeah no worries. the discussion did seem a bit familiar.
Old 27-02-2007, 06:58 PM   #17
mcflux
mcflux's Avatar
lol
Well Burkie in light of the resulting couple of posts between myself & prydey, DON'T take my starting RPM (or prydey's resulting RPM) as gospel.
However the maths behind the RPM change is 100% correct. So whatever your starting RPM is, divide it by your old diff ratio & multiply it by the new ratio you want ;)
