Old 27-02-2007, 07:58 PM   #1
burkie_21
wild xr8
burkie_21's Avatar
Default roller rockers, worth it or not???
i was looking at buying yella terra roller rockers, shopped around at various performance stores and got different answers which confused me more. is it worth spending the money for them cos some people say they are a waste unless ur engine is doin about 7 grand, others say they are a must have. the little i know about mechanics is that they jus help with valve bounce yeah??? if so can i jus use a tighter spring??
burkie_21 is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2007, 08:52 PM   #2
BLSTIC
the idea behind them is that they can move faster with less resistance, the only real benifit of a roller rocker is at high rpm (less power needed to move them, lowers stress on most valvetrain components).
The other benifits are actually what you tend to get when you change rockers anyway. Ie you can make them lighter and/or stronger than the factory part (when it's lighter you can run at higher rpm without running into valve float. Lets you run a lower valve spring rate.), and you can make them a different ratio to open the valves further. Kinda like getting a cam with more lift.
Do these cars already have roller cam followers? I know the 6cyl's do...
cya
Ben
BLSTIC is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2007, 08:56 PM   #3
OED666
OED666's Avatar
the 6's already have them. v8's however are a different story.
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2007, 07:45 AM   #4
LTDHO
The one and only
LTDHO's Avatar
They do?
I have never seen a factory 6 with rollers!
Tuned by CVE Performance
Old 28-02-2007, 05:37 PM   #5
steven95falc
ea-ef had them
steven95falc is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2007, 05:40 PM   #6
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
yes, the i6 has roller rockers LTDHO.
There is no benefit with changing the rocker assembly on an I6.
Change the valve springs, cam and make the head flow more..
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2007, 06:06 PM   #7
steven95falc
And if your a complete ****** like me when some idiot comes up to you and asks what youve done to your motor if its a stock ef like mine you can say shee's got rollers flat tops and a cam and you havent lied
Old 28-02-2007, 06:08 PM   #8
BLSTIC
Hmm true... I might use that line at macca's one day... But a cam, that means a hot cam most of the time, no?
That said, an EF cam is apparently a big upgrade to the ea-d's...
