Old 02-03-2007, 04:37 PM   #1
johnydep
johnydep's Avatar
Default LPG safety warning
This may help some of you.
http://www.mta-sa.asn.au/docs/page/1...asurer.gov.pdf
SAFETY WARNING ON VEHICLE LPG TANKS
The Parliamentary Secretary to the Treasurer, Chris Pearce, today issued a safety warning to owners of motor vehicles which had LPG conversions or who had their LPG tanks retested between mid 2003 and August 2005.
“Since early 2005, there have been a limited number of pressure ruptures of LPG tanks on motor vehicles, so far without causing any serious injury.
However, rupture of an LPG tank due to a build up of pressure can generate very significant forces with the potential for serious injury and damage to property. Most of these incidents involved vehicles with two or more LPG tanks fitted,” Mr Pearce said.
The safety relief valve designed to relieve any adverse build up of pressure in the LPG tank/s may not function as intended, depending on the type of valve used and the torque levels used during installation.
If multiple LPG tanks are fitted and the fuel service line to the engine from one tank is closed, so that no fuel is used from that tank and it is maintained as a reserve tank, that tank may gradually overfill and may rupture if the pressure relief valve fails to operate correctly.
Motorists who had LPG tank installations or tanks retested between mid 2003 and August 2005, in particular if two or more tanks have been fitted, are requested to contact an LPG tank installer/fitting station to arrange an inspection and pressure relief valve replacement if required.
Vehicle owners should negotiate with the LPG installer/fitting station on an appropriate fee (if any) for any corrective action required. If the tank/s are “Manchester” branded tanks which were fitted between August 2003 and April 2005, these are subject to a voluntary recall and the pressure relief valves fitted will be replaced at no cost.
21 December 2006
MELBOURNE
Contact:
Conor O’Brien - 03 9887 3890 or 0402 970 515
The true danger only occurs when you take a potentially dangerous piece of machinery
and place it in the hands of the most unpredictable species on the planet.
Human behaviour, as history has catalogued, cannot account for what any persons actions may be,
especially concerning their love of the motor vehicle.
http://www.fireservicecollege.ac.uk
johnydep is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2007, 04:41 PM   #2
GasoLane
Former BTIKD
GasoLane's Avatar
Thank you. But shouldn't this be in the LPG forum?
Old 02-03-2007, 08:39 PM   #3
trick_xd
I build your wish list...
trick_xd's Avatar
Yes this is old and been out for a little while
It is most common in a duel tank setup where you keep 1 tank as a reserve.. the gas feeds into the "reserve tank" so it over fills and "Boom"
you can check yourself if you have that sort of relief valve just by looking .. it will say SIDEK PRX on the top of the valve .. if you do take it to a Gas Place and they will change it for you free of charge (well there meant to) and if you have gas in your tank they will suck it out and fix the tank and put your gas back in for you..
If it weren’t for physics and the law enforcement, I’d be unstoppable.
trick_xd is offline   Reply With Quote Multi-Quote with this Post
