Old 03-03-2007, 03:24 PM   #1
Noddy
Mercury Silver T3
Noddy's Avatar
Default Set top box pin number????
Anyone know what the installation PIN is on the older uec sd set top boxes is?
House of Tickford
T3 TS50 No.156
AUIII XR8 220
2017 Magnetic Mustang
What to hear a tuff T3?
Click here
http://s7.photobucket.com/albums/y30...ent=Movie2.mp4
Noddy is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2007, 03:32 PM   #2
uranium_death
uranium_death's Avatar
Have you tried just entering zeros?
From there, maybe you can nominate a combo.
uranium_death is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2007, 03:39 PM   #3
Noddy
Mercury Silver T3
Noddy's Avatar
Yeah i did and its incorrect, it says its located in the handbook but i have no idea what i've done with it. I want to change signal input, at the moment its on composite and i want it to feed s-video.
House of Tickford
T3 TS50 No.156
AUIII XR8 220
Click here
Old 03-03-2007, 04:12 PM   #4
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
If i remember correctly , it was 9949 for the older sd units. gl.
I think the newer models use a factory preset is 0611. cheers.
:eclipsee_
Old 03-03-2007, 04:30 PM   #5
Noddy
Mercury Silver T3
Noddy's Avatar
SOB, i swear i remember seeing 9949 somewhere before, neither of those numbers worked.
House of Tickford
T3 TS50 No.156
AUIII XR8 220
Click here
Old 03-03-2007, 04:37 PM   #6
XR6-VCT-2000
Fantastic Plastic
Yeah well i could of sworn that was the number for the older foxtel uec sd units, are you sure you haven't changed the pin on your unit in the past ?
The only other pins that sorta come to mind for older SD stb's are
8272
6666
7942
Although i cant remember what brand units these codes were from though ( i used to mess with alot sd cable unit years back ). You could give them a try , no harm done.
What is the brand name & model number of your sd stb ?
:eclipsee_
Old 03-03-2007, 05:09 PM   #7
Noddy
Mercury Silver T3
Noddy's Avatar
ok found it, 1379. Thanks anyway.
House of Tickford
T3 TS50 No.156
AUIII XR8 220
Click here
