Old 25-03-2005, 02:41 PM   #1
GROOV3
Rollin
GROOV3's Avatar
Default Unlock your digital spedo (FYI)
Hey all
This will give you digital readings for your speed in mph, the amount of fuel left in miles to go, your revs in digital form, your engine temperature plus more.
NOTE!!!!!This process will not harm your car in any way you just loose your current odometer reading.
Functions
Gage Test
Dial Test
Bulb Test
N/A
N/A
Clock Type (shows “date 44” if UK)
Un
Speed MPH
Speed KPH
Revs
Fuel
Engine Type
Temp of Engine
Battery Voltage
N/A
LCD Display
(17-30 N/A)
now i had a quick play but its quite over rated and you have to do it every time you start the car.
what you do is have the car turned off push in the odometer trip button for 10 secs then keep it held down and start teh car and dont let go till you see the word test come up then you can let go and press the button to cycle through the different things
GROOV3 is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2005, 03:00 PM   #2
Teki04
Clio 182 CUP!
Teki04's Avatar
how did you figure that? ill be trying it out to see how it works. Sounds good
Steven
'In fact, so good is the Clio 182 with the Cup chassis set-up that I feel moved to make a bold statement - I think it's the best hot hatch ever built.' (EVO Jan 04)
Teki04 is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2005, 03:05 PM   #3
GROOV3
Rollin
GROOV3's Avatar
people in the uk try and sell it on e bay but was posted in UKFeznetwork
its what ford use when they service the car it tests bulbs guages etc
Old 25-03-2005, 03:13 PM   #4
Teki04
Clio 182 CUP!
Teki04's Avatar
Awesome... im gonna try it forsure
Steven
Old 25-03-2005, 04:47 PM   #5
Fez WQ
What model is this on I have a fiesta LX 5 door
Fez WQ is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2005, 05:24 PM   #6
GROOV3
Rollin
GROOV3's Avatar
mk6 any model
Old 25-03-2005, 06:35 PM   #7
fordel
Tricolore Tard
Contributing Member
fordel's Avatar
Yeah its the same process as it is for the focus models
Pointless as it doesnt stay like that when you turn the car off and you lose the odo reading which i use a heap
Pity its not like the E series ones which at least keep the current odo reading
Chris
fordel is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2005, 10:33 PM   #8
csv8
csv8's Avatar
do you lose the odo or tripmeter readings. I thought odo readings weren't allowed to be altered by law?
Old 19-04-2005, 05:57 PM   #9
Danny
GT4.
Danny's Avatar
Obviously the tripmeter reading....
Deja vu big time for me, as I used to constantly use it in the EF so i knew how much (or mostly how less) fuel i had to play with before it ran out...
-Dan
Danny is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2005, 06:10 PM   #10
Stevo
Yeah, i used to do that on the EF alot too.
Stevo is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2005, 07:27 PM   #11
Cypher
Fiesta Zetec
Cypher's Avatar
So it is ok to drive around like this and it will not have any adverse effects on the car??
There is some handy stuff available there
Cypher is offline   Reply With Quote Multi-Quote with this Post
