#31 | |||
The one and only
Usually the rings won't seal well, blow smoke, due to oil rings not sealing and can have low compression due to compression rings not sealing. No easy fix, need hone and new rings, and running in procedure done properly and the motor warmed properly.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
#32 | ||
Posts: n/a
I've always warned my car up.
Give her a flick into electrical on (no engine power) for roughly 30 seconds, to let the barrery kick in, then fire her up for a few minutes. I got my house keys and car keys on the same key ring, but on a clip, so i can take my car keys off, start her up, go inside grab my stuff, lock the doors which makes up the 4-5 minutes for a good old warm up ![]() |
#33 | |||
#34 | |||
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust |
#35 | |||
The one and only
#36 | |||
X-Series Club Moderator
PROJECT - '77 XC Falcon 351C - Click Here DAILY - '05 Ford Territory BIKE - '12 Suzuki GS 500 |
#37 | ||
I cant see the validity of the argument to NOT warm your car up thoroughly.
With my XA - I cant drive it and keep it under 3000rpm. You can try - but its got a big cam and is a pig to drive at those revs. When it's fully warmed up I believe I can safely then drive it at the revs specific to that combo with less risk of damage. Im trying to understand the reasons behind warming up being bad. Why/how do the bores glaze if warming up? Why dont they do it if you dont warm it up and start driving it straight away? How can warming up do more damage than starting the key, giving it a minute or two and driving off????!!!! Help me to understand. Im not saying what is right or wrong here. I will say I know my car - and if I were to simply start it, give it 15 seconds and drive off - it sure doesnt feel like its not doing it any damage!!!! |
#38 | |||
Kiwi Ford Nut
I concur with waiting until the oil pressure comes up (only takes a few seconds in reality), then I drive off and dont thrash it until some heat has gone into the engine.
Black AUII 5.0L Fairmont, Koni Adjustable Sports Shocks, King SL Rear, SSL Front. Pacemaker TRI-Y's and 3" Rage exhaust, Willwood 4pot front callipers with 325mm directional vaned rotors. Still to come :- 6 speed manual conversion, head, cam and of course a blower! |
#39 | |||
RAGE Engineering
On cold startup, the engine is running a rich mixture which "washes" oil from the cylinder bores. Prolonged idling means the engine is running a rich mixture for longer periods as opposed to a short idle time and easy driving until your water temp comes into normal operating temperature. Its at this point your ECU will lean out the mixture and go into closed loop. Generally speaking, the sooner this happens the better. The longer it takes the car to warm up above the vapor point for the combustion byproducts, the larger the amount of particulate formation and growth. This leads to sludge, varnish and particulates in your oil. In addition to the wear these types of particles cause, you also end up needing to change your engine oil more frequently because these get you to your oil's particulate threshold faster.
If it doesn't fit, use a BIGGER hammer Last edited by FFOracing; 15-04-2005 at 06:18 PM. |
#40 | ||
I start it with a bit of choke, and move off as soon as possible. I don't live far from a decent stretch of road, and it normally warms up as I putter along.
I can't sit at home at 5.15am trying to warm up an old school V8... My neighbours don't appreciate the exhaust note as much as I do, especially in the middle of winter. I've got pretty good neighbours, I prefer to keep it that way.
Current Rides: 2000 AU 5L XLS ute; 1970 Mustang project |
#41 | ||
Hey FFO - man thanks for the response. Very impressive!!!
![]() One question - you talk about ECU's. Its just not them though? The same theory (of rich mixture washing oil away) would apply to carburettor engines too? |
#42 | ||
I usually let the Lynx warm up and warm down.
or if I don't have time to wait I keep it off boost till I start to see the temp gauge move up. warming down time depends on how I have been driving just before I am going to turn it off, if I haven't been on hard boost and have mucked around a bit while parking it doesn't stay on long, but If I have been doing quite a few 7000rpm changes just before stopping it gets a good few minutes at least till the fan kicks out. With my new Astina it just gets 20 seconds or so and then I'm off and no warming down, no point its not turbo.....yet! Rob |
#43 | |||
![]() I have just been discussing it here http://www.fordforums.com.au/showthread.php?t=7511 Steve. |
#44 | |||
RAGE Engineering
If it doesn't fit, use a BIGGER hammer |
#45 | |||
It is hard...
I could eat a knob at night... |
#46 | ||
there is alot of confusion about warming up any engine whether its efi or carby. do you wait for the water temp to get up a bit, or oil pressure or just count in minutes. Well the most IMPORTANT thing is actually oil temperature, but it is very often overlooked. How many people have oil temp gauges in their hotted up cars???
it is often the case in engines, that after a couple of minutes the car can have close to normal water temp, but still not have good oil temp. obviously the oil needs to be at a certain temp to do its job properly, and to aviod wear. |
#47 | ||
Former E-Series Member
Another factor to throw into the mix, alloy head engines need to be warmed up as slowly as possible to avoid warping the head gasket with the different expansion properties of alloy and iron, and idling is the logical way to do this. I suppose the bottom line is that there isn't an absolute right or wrong.
#48 | ||
certain oils also work at certain temps dont they? like the more expensive ones are made to be effective at lower temps....
my car starts first time everytime, and has never once stalled on me, no matter how cold it is at 4am. i usually get in, start it up and give it a minute or so if i have time, then drive it nice and easy till the temp gauge is up.....if i dont have time, i start it and go, and it goes fine, but i dont drive hard until the temp gauge is up |
#49 | ||
i hardly ever warm mine up
i never try rev its gutts whilst cold nor drive it hard from the word go,i putt about till it warms up.. |
#50 | ||
Not my bloody wifey she backs out on to road,motor only going for about 45secs and the floors it,I hate it. I at least get a couple of streets away before giving it some. Then she complains when I kick it in the guts at 100k to overtake sumone.
sorry folks I have a BA xr6 it wasn't until I read back through the posts that I realised you were mostly talking about your hot XA's and other older cars.
igodabigblackshinycar and I relented and allowed a BMW into the garage. ![]() Last edited by deesun; 16-04-2005 at 02:16 PM. |
#51 | |||
#52 | |||
Rider on the storm
![]() Last edited by Biggoggs; 16-04-2005 at 10:17 PM. |
#53 | ||||
Detroit Locker Equiped TM
Apollo Blue 1974 XB Falcon GT, 557 HP Blue Pearl 2004 BA FPV GT, 290 kW Quote:
http://www.facebook.com/FalconGTClubGeelong |
#54 | ||
![]() Join Date: Dec 2004
I drive very gently (<1/4 throttle) until the temp gauge is above C, in the normal operating range. The car doesn't seem to mind
#55 | ||
while we are on the subject of water temp gauges, it is interesting to know that alot of manufactures make their gauges so that normal operating temp is actually under half way or in the cold range (e series falcon's as one example)
it is supposed to be much more pleasing for the driver to see colder all the time, allthough, this means that when the gauge is at normal or starting to get hot, its actually getting very hot, more like gasket popping hot. |
#56 | |||
#57 | ||
My EA guage reads exactly half way pretty much all of the time.
#58 | ||
how do u know "normal" is actually normal operating temp in terms of degrees celcius? it could be 50 degrees or 80 derees depending on how the manufacturer has Calibrated the gauge. i struggle to get them to R in normal when i drive them, but its not uncommon for them to overheat either.
but then again, when u cook an E series to the point where the coolant is boiling and starts to evaporate, the sender unit can't work when not submerged in water so the gauge goes back down to cold, even though the head is closer to melting into a puddle of alloy at this point. good old E series falcons, keeping engine reconditioners in business all over australia. |
#59 | ||
My Ford owners manual says not to idle for prolonged periods, what prolonged periods is, ??????? my temp gauge always sits on just above L, when its 45 outside, it will sit on M, which is 95 degrees.
