Old 03-06-2007, 01:57 PM   #31
CAMS290
trying to get a leg over
CAMS290's Avatar
Wouldnt be a Turbo diesel prototype would it ?
Cameron
CAMS290 is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2007, 02:46 PM   #32
fou_bleu
Get EcoBoosted
fou_bleu's Avatar
Would be good if it was a V8 turbo diesel!
XR8-Turbo Diesel?
fou_bleu is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2007, 03:58 PM   #33
csv8
csv8's Avatar
XR8-Turbo Diesel?
FORD should speak to VW and get the V10 Diesel from the TOUREG!!!!!!!
csv8 is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2007, 05:23 PM   #34
Powdered Toast Man
Professional Mouse Jockey
Powdered Toast Man's Avatar
XR8-Turbo Diesel?
Yeah they should use the new one that aquahead2001 mentioned thats in the Land Rovers, the 3.6V8 TDI. I bet they dont though.
Need something to compete with the General. Isnt there talk of a large capacity V8 diesel for the Commodore? Probably just speculation though.
Isuzu MUX for towing horses - currently no Fords in the stable
Time flies like an arrow; fruit flies like a banana. Groucho Marx
Powdered Toast Man is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2007, 06:02 PM   #35
Bossxr8
Peter Car
Bossxr8's Avatar
The VM Motori engine that Holden are rumoured to be using makes 180 kw and 500nm. That would make the 2.7 TDV6 pale in comparison as its 140 and 440. If Ford do use that engine it will be underpowered even before its released if Holden use the VM Motori engine. The 3.6 TDV8 is a better proposition at 200 and 620, but the fuel economy is only 11l per 100 in a heavyweight Rangie, which wouldn't be much better than that of a current petrol powered Territory even though the Territory would be a bit lighter. Thens there's the problem of not being able to fit V8's to the Territory, even though a V6 would probably have the same steering shaft clearance problems.
Old 03-06-2007, 10:01 PM   #36
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
there is a V8 terry in geelong. has a big sticker on back window
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw)
2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned)
Mr_4.0 is offline   Reply With Quote Multi-Quote with this Post
