Old 26-05-2007, 09:01 PM   #1
v8ghia1
v8ghia1
Default mk1 axle stuck on removal?
Hi,
I own a mk1 panelvan,
I purchased a chrome diff for it, minus axles and centre,and want to remove my running parts to install into the chrome diff.
I have removed the panelvan diff,unbolted the diff head bolts and am stuck on removing one remaining axle?
Cheers,Zane
v8ghia1 is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2007, 08:57 PM   #2
dnorris
norris
there's always one .... you could try a little heat ,oxy
dnorris is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2007, 08:21 AM   #3
whooligan
whooligan's Avatar
Worse comes to worse, source another diff. IF you are having trouble removing the axel, it might well be bent.
whooligan is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2007, 08:31 PM   #4
dougo
frog joke at the cricket
I had a similar problem on the last restoration we did, am assuming the bearing and everything is free....if not this is what we did.....jack the car up and support it with stands or somethign solid......take the brake drum off and place it back on the studs but the wrong way round so the inside of the drum is facing outwards......bolt it on with the wheel nuts.......get a BIG hammer, a lump hammer we used to call them when i was a sparkie, and give it a few really hard firm strong hits.......this could take a fair degree of effort but we got it out in the end. The car was a bit of a hack and the bearing was rock solid, once we did this and freed the bearing, the axle slid straight out.....not saying you have the same problem but maybe worth a go.....cheers
dougo is offline   Reply With Quote Multi-Quote with this Post
