Old 08-06-2007, 09:43 PM   #1
TEaaron
TEaaron's Avatar
Default What's involved in putting a t5 in a TE cortina?
Tital speaks for it self
TE cortina 14.0 @ 101mph
E32 740iL Leather, sound system, rollin' on 19's
TEaaron is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2007, 10:20 PM   #2
P100 Ute
P100 Ute's Avatar
Things u need
XF T5 bellhousing + throwout fork etc.
T5 from a XF --> EL (AU's are 100mm further back than the XF-EL's)
prob get a Flywheel from the same XF u get the Bellhousing from.. and keep the bolts.. theyre different length to the Auto Flexplate ones
XF T5 clutch cable.
What To Do
Cut a hole in the floor of the car as the T5 sits 100mm further back than normal... dummy fit the box and mark where to cut..
might have to drill the rear 2 holes a bit larger on the auto gearbox crosmember. and possibly shave the front a bit
Auto tailshaft will fit in the back no worries.
unbolt the electronic speedo from the T5 and plug the corty speedo cable in it.. that fits no worries..
connect up the plugs for reverse lights n neutral safety switch etc.
drive away..
im doing this conversion to a TD prob this sunday..
heres some photos.
P100 Ute is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2007, 11:24 PM   #3
TEaaron
TEaaron's Avatar
Thanks heaps
