01-04-2005, 07:33 AM | #1 | ||
Just a quick one, Will an EA auto box bolt straight into an EB?
1991 EB Fairmont: Wrecked 1993 ED Falcon: Gone 2005 BAII Falcon: Sold 2006 BF Falcon |
01-04-2005, 08:51 AM | #2 | ||
Yes........
2003 Narooma Blue BA XR6 5spd Manual. Pacemaker 4490 Extractors 2.5" Exhaust High Flow Cat SS Inductions "Growler" CAI Underdrive Pulley Mal Wood H/D Clutch Custom Tune 18" XHP Sabre's 12" Kicker Sub 169.2 rwkw
01-04-2005, 09:02 AM | #3 | ||
Adapt or perish...
Why in the blue hell would you want to put an EA auto in an EB?
Carless
01-04-2005, 09:05 AM | #4 | ||
PM me if you want
3 speed auto - it wont bolt in - mount points are all wrong.
4 speed auto - will be fine If you can spell put a little more what your intended plan is, I can give more information :
01-04-2005, 09:07 AM | #5 | ||
Last warning
if its an EA 4 speed.. i don't see why you wouldn't?
they're pretty cheap and if urs is on the way out?
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
01-04-2005, 09:47 AM | #6 | ||||
01-04-2005, 09:56 AM | #7 | ||
Last warning
i think dellboy meant to say 'if u can spell out'
ie. explain ur plans
01-04-2005, 10:26 AM | #8 | |||
PM me if you want
01-04-2005, 11:08 AM | #9 | ||
No probs however I did have to check my spelling just to make sure
01-04-2005, 11:26 AM | #10 | ||
PM me if you want
EA-EF all the same wiring assignement, EL hybrid and AU are different (AFIK)
01-04-2005, 07:56 PM | #11 | ||
Prince Of Darkness
If not i got a EL 4 Speed Auto looks liek just been reconded and newish torque convertor
Engine; 351 Crank, 302 Rods, Custom Pistons, Blue Print & Balanced Bottom End, Crower Stage 5 Cam (Cam Specs), , CHI 3V Heads. ENGINE PIC HERE Body: XD Fairmont Ghia |
24-04-2005, 06:43 PM | #12 | |||
Location: Nowra (Southcoast) N.S.W. Beutiful beaches no smog & plenty of grog & yes that is my dog.
05-05-2005, 06:34 PM | #13 | ||
I didnt get the box. the guy decided he wanted $100 for it.
so Spider_GT how much do you wand for the box? and today I only had 3rd gear is my box at the point of no return? how much would it cost to fix my box? is it worth it? ohh and I am trying to spend as little money as posible. Thanks
05-05-2005, 06:50 PM | #14 | |||
Even when i was stopped at lights it took off in 3rd.
05-05-2005, 07:14 PM | #15 | ||
your box may be fine. it sounds like there is something else causing a problem. 3rd gear only is a limp mode.
don't be too quick to replace your box you may not need to
EF Falcon Sedan 5.0 auto with IRS "the man that crashs AFF" |
05-05-2005, 07:35 PM | #16 | ||
Custom user title
make sure youre car has good body earths and a good engine to battery earth.. run some new thick cable.. when it goes into 3rd next time, turn the key of and on and it should be fine again
06-05-2005, 10:26 AM | #17 | ||
You could be onto something there because the battery light has been coming on in the mornings and a warning buzzer. I just give it a quick rev and its all good. I will look in to it further. Thanks
06-05-2005, 03:19 PM | #18 | ||
I was going to say check your fuse, but then I realised "duh! He said it's OK sometimes!" so it won't be the fuse (as was the case with mine when it went into limp home mode) a couple of weeks ago)...
Must be somewhere in the wiring/earthing as others have said. Good luck finding it, & let us know how u go. -Dave- |
20-05-2005, 09:56 PM | #19 | ||
Ok save starting a new post will a 4 speed box from a EL Futura Sapphire.
bolt straight in?
21-05-2005, 07:42 PM | #20 | ||
Anyone
