Old 25-07-2007, 08:44 PM   #1
da_ilks
da_ilks's Avatar
Default Service Intervals
Guys,
The XR4 has gone in for it 3,000km check, so it's not due back to Ford until the 15,000km mark. There is an optional service for every 7,500km's, which I am currently thinking of following
My question is - is 15,000km service intervals OK? I've always done my other cars every 5,000km, so 15,000km seems extreme. The majority of my driving is highway/city (probably 80/20 split) but of course there's the occasional thrash through the hills. Is it worth spending the extra money doing the optional 'C' service, or just let it go and do and the normal A + B's?
da_ilks is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2007, 11:07 PM   #2
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
Chris just change the oil yourself between services. Ford overcharge to get an apprentice to change your oil.
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2007, 11:07 PM   #3
Ives
Ives's Avatar
If you're using good quality full-synthetic oil, then it's ok to service it every 15,000kms. A mate of mine also got 7,500kms written as the next recommended service.
Ives is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2007, 11:34 AM   #4
da_ilks
da_ilks's Avatar
Yeah no doubt about the overcharging - suppose they won't know if I've done it anyway (extended warranty, no one is allowed to touch the car) Anyone know what oil Ford use in their regular servicing? Only disadvantage is the book won't be stamped.
Expensive stamp.
Old 26-07-2007, 11:51 AM   #5
Ives
Ives's Avatar
I doubt Ford uses the recommended 5W-30 because "It's too thin for Australia condition" (which I think it's bogus).
Old 26-07-2007, 12:49 PM   #6
Piotr
Non-Regular Member
It is bogus, the manual says 5W-30 will work from below -30c to over 40c. 10w-30 is fine aswell.
Piotr is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2007, 02:25 PM   #7
robjh80
robjh80's Avatar
Change the oil yourself in between services at 7500km using a good quality Synthetic oil.....just make sure you use the original Motorcraft Oil Filter from Ford to safeguard your warranty, (ie: they wont know you've done it yourself), dont use the Ryco aftermarket etc otherwise of course they would know.
When I was buying the Motorcraft one from Ford when I had my Fez it wasn't too bad pricewise, only about $15 which is about what the Ryco ones are anyway.
robjh80 is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2007, 04:12 PM   #8
da_ilks
da_ilks's Avatar
If I do them at home I'd rather use the same oil as Ford - not a fan of different oils every change....
Anyone know what brand Ford use?
Old 27-07-2007, 05:12 PM   #9
Outbackjack
Central to all beach's
Outbackjack's Avatar
Just ask the ford guys that service your car. I buy all the oil for our cars (Fiesta and XR8) in bulk. Works out much cheaper. There is no good reason that ford wont tell you. Unless they think that they are missing out on the $$ for their apprentice to change your oil. And BTW, I alway put a little texta mark on my oil filters before I put the cars in for a service. I have never had a problem with the local ford/mercedes dealer, but caught out the local holden/nissan/toyota/mitsy/honda dealer twice.....
Real Aussie muscle cars have a clutch!!
http://www.roadsense.com.au/about.html
Outbackjack is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2007, 06:05 PM   #10
Ives
Ives's Avatar
Every dealers can use different brand and viscosity of oil. Some uses Castrol and others Shell.
Old 27-07-2007, 07:08 PM   #11
kiwijohn42
Death B4 Decaf
kiwijohn42's Avatar
You might have to point them at the service manual if they ask why you want 5-30w oil. I specified Castrol Edge 5-30w when I had my last service & they still put 15-40 in it.
I also change oil & filter at 7500km myself. Not sure if it's really necessary on a modern car, but oh well.
06 fiesta Zetec in Tango. Factory scuff plates, mats, spoiler & leather gear knob. K&N panel filter. Focus clear side indicators. Colour coded.
kiwijohn42 is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2007, 11:03 PM   #12
csv8
csv8's Avatar
My FORD dealer uses Castrol Professional, whatever that is, supposed to be fully synthetic in my FIESTA, the FAIRMONT they use MAGNATEC and changed every 15000kms
Old 30-07-2007, 03:54 PM   #13
Als_Zetec
Rated G
Als_Zetec's Avatar
Hey buddy
I do an oil change at 7500km in between each 15,000km service. I change the filter as well and use either a 10w-30 or a 5w-30 fully synth oil. The difference after the oil change is noticeable. The car is idling smoother and pick up is sensational. I find that the synth oil is far superior to the mineral oils. When my car is serviced I always request synth oil, and where that's not possible they use a semi synth.
The oil that I use most often is the Fuchs, but this may vary according to what's on special and if I am trying something that someone recommends. Generally, I don't use Castrol / Shell or generic brands. Overall, I'm really happy with the Fuchs.
As others recommend, use the Ford OEM filter and give it a shot. If you like the results, stick to doing it yourself and save the cash. When its time to sell, your passion for and attitude towards your car will be obvious to the buyer even when there is no stamp in the book.
Cheerio
Ali.
05 Fiesta Zetec... unique Tonic body colour,
leather gear shift, floor mats, scuff plates
rear spoiler, basic tints, 15" stock alloys
Als_Zetec is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2007, 08:13 PM   #14
da_ilks
da_ilks's Avatar
Thanks for the advice guys. I'll speak to Ford and see how much a C service is. If it's not overly expensive I'll probably head that way. Not that I'm lazy (well, I am actually:p) but yeah, just easier to avoid any potential dramas with my extended warranty.
Old 24-08-2007, 04:19 PM   #15
da_ilks
da_ilks's Avatar
Just an update, a C service is $125. Expensive oil change + stamp
Old 24-08-2007, 04:23 PM   #16
robjh80
robjh80's Avatar
Very expensive, that's why you do it yourself, not to mention oil change jobs are usually the "apprentice jobs"......Vroom Vroom!!
