Old 31-08-2007, 10:29 AM   #1
willygrice
Default Disc Brakes and Tougher Diffs
Hi guys I talked to hopper stoppers about rear disc brakes and their option was their weld on disc brakes. They also mentioned however getting an EA-EL falcon diff shortened. I tried researching this on the net and couldn't find anything, all I found was a little bit about Hilux diff conversions.
Questions.
How much would I be looking at spending to have a diff shortened, fitted and engineered?
Hilux or falcon better?
Suggestions?
willygrice is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2007, 10:37 AM   #2
V8falcons
V8falcons's Avatar
what car are you putting it in?
T2 TE50 no:154 Narooma blue
AU2 XR8 ute
XR4 fiesta
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2007, 01:21 AM   #3
willygrice
Sorry, MK2 Escort
Old 02-09-2007, 01:52 PM   #4
kiwirsman
why dont you just use a narrow atlas diff strong as buggery and they came out in capris downside being conversion kits for discs are expensive but they do have the 9 inch drums
kiwirsman is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2007, 12:01 AM   #5
EskyCosworth
RS2000 COSWORTH
Try the Borg Warner 8/3/4 (Falcon, R31 skyline etc all the same) $1800 all ready to go.
Even better is to use a Kaaz multi plate clutch LSD $1150, it will be unbreakable and extremely useful for the handling of your car. Mine loves copping 242kW atw on the street and racetrack.
The Atlas is also an exceptionally good option and would suit your needs, but might be difficult to get a hold of.
The Hilux is also another option with a lot of ratios to choose from.
Summary - a good quality and reliable set up is not $1...
EskyCosworth is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2007, 08:08 PM   #6
V8falcons
V8falcons's Avatar
ah unless your ford specific use an early hilux or ford/mazda b1800 diff,they have plenty of ratios to choose from,very big axels,LSD available and can be had for very little ,the beauty of these is they are very close to the escort width +5mm overall you just need to machine the hub to suit your wheels and redrill the PCD.
AU2 XR8 ute
XR4 fiesta
Old 14-09-2007, 02:16 AM   #7
beem
Questions.
Suggestions?
At home in Ireland we use the Standard English axle with uprated group A half shalfts then use Escort XR3i discs and calipers.
beem is offline   Reply With Quote Multi-Quote with this Post
