has anyone put m/bike throttle bodies onto a "kent' donk, if so what sort,and manifold ??, as I have a MOTEC ecu etc and want to efi my motor as cheap as I can pls
#2 | |||
Thanx, great links... I was hoping for a local supply, or if someone has the info required, as in they made a manifold and used a certain type of T/B`s etc, or I was thinking of using an EA centrepoint injection set up on my webber manifold, but it still needs tweaking anyway as the EA body is wider
#4 | |||
thanks, my motor is fully worked, larger valves, ported, 28/68 cam, 40thou over, told to run prem unleaded, 11- 1 compression, elec ign,extractors-2.25 exhaust..... ant thoughts on the EA centre point ??, seems easy enough,just a bit of fiddling tho
#6 | |||
