Old 13-10-2007, 05:55 PM   #1
FPV70
Default Gear Ratio's
I am not too sure if anyone has ever asked the question but, Back in the glory days of the old GT's and maybe Cobra's you used to be able to pick a diff ratio am I correct?
If I am correct, why is it that thesedays we can not choose a ratio that we might like and why are we stuck with a high final drive like 2.92:1?
Yeah great top end but howabout a better sprint??
I believe Holden use a slightly lower Final drive to Ford which would inturn give a good fuel return around town and with the 6 speed auto's and manuals thesedays, I am sure we could do with a slightly lower final drive aswell.
the 290 and 260 would both stand to gain more from it unless the first gear ratio in the gearboxes is too low as they are which would be the only downside I can see.
Anyone else have an opinion?
FPV70
Falcon PanelVan 1970
FPV70 is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2007, 05:58 PM   #2
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
With the ZF 6speed auto Diff gear changes are a thing of the past.
Great acceleration and economy on highway.
Falcon Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2007, 06:55 PM   #3
T3man
T3man's Avatar
There was no choice of ratios on Cobras.
The choice of diff ratios finished with XY. Even then, it was only offered on the GTs, utes and vans, but not mainstream sedan models. From XA through to XF you could option a "lower" diff on commercial vehicles ie. utes, vans, and in some cases wagons (earlier years only).
So few people chose the option that Ford decided it wasn't worth the effort and as far as I know there have been no alternate diff ratios offered ex-factory since the advent of the E-Series.
Anyone interested can choose from several after-market suppliers to do it anyhow.
Old 13-10-2007, 08:53 PM   #4
cowboy
Cowboy
cowboy's Avatar
The BF XR8 ute brochure lists a another diff ratio as a factory option. Can't remember if it's taller or shorter. Taller I think.
1927 Pontiac tourer
1928 Pontiac tourer
1929 Pontiac sedan
1930 Pontiac Landaulet
1932 Pontiac V8 sedan
1935 Pontiac sedan
1937 Pontiac 8 sedan
1948 Pontiac silver streak
1949 Ford F3 pickup
1953 Pontiac Chieftain
1955 Austin Champ
1957 Dodge Power Wagon
1967 Jeep Gladiator
1975 TD Cortina
1978 F100 4x4
2006 GU Patrol ute
cowboy is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2007, 10:02 PM   #5
Bent8
Long live the GT !
Bent8's Avatar
Ford chose the 2.73 ratio for the ZF's because they have a broad spread of gear ratios 1st and 2nd being low ratios. A BF XR8 will do 62kmh in 1st, 111kmh in 2nd and cruise along @ 110kmh in top gear pulling only 1700rpm...
If Ford went with say a 3.23 then you wouldn't even hit 100kmh in 2nd which would seem kind of silly...the 6sp manuals are geared better with a tigher spread of ratios eg the ZF will do 175kmh at the end of 3rd while the 6sp manual will only do 155kmh...
That being said, I think it would be a great idea if Ford still offered different diff ratio options when spec-ing your new car...
2018 Ford Mustang GT - Oxford White | Auto | Herrod Tune | K&N Filter | StreetFighter Oil Separators | H&R Springs | Whiteline Vertical Links | Ceramic Protection | Tint
"Whatya think of me car, XR Falcon, 351 Blown Cleveland running Motec injection and runnin' on methanol... goes pretty hard too, got heaps of torque for chucking burnouts, IT'S UNREAL !!" - Poida
Bent8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2007, 10:45 PM   #6
FPV70
Well thanks for that info guy's. It now makes more sence and also confirms the reasoning for the taller ratios.
Now I can stop those nagging voices in my head as to why/why not
FPV70
Old 13-10-2007, 11:11 PM   #7
Barry_v
rocknrolla
Barry_v's Avatar
they offered different rear end gears because they had no overdrive and only 3/4 forward gears.
1979 P6 LTD 383c
1970 ZC Fairlane 500 351w
1964 XM Falcon Deluxe 200ci
Barry_v is offline   Reply With Quote Multi-Quote with this Post
