The wifes Fez has just clocked up 10 K and it seems an awful long wait to the 15 K suggested service, so I thought I might change the oil. Can someone make suggestions on the best oil in the recommended viscosity, and the filter, or should I go OEM filter?? Any input appreciated.
Ta, Jay |
Death B4 Decaf
Standard ford filter should be fine. I've got a Ryco on cos ford was shut when I needed it. I use Castrol Edge Sport 5-30W oil & I wouldn't trust the dealer to know that's what it should run.
15k does seem a long time so I change mine every 7.5k. I do think the economy improves with good new oil.
06 fiesta Zetec in Tango. Factory scuff plates, mats, spoiler & leather gear knob. K&N panel filter. Focus clear side indicators. Colour coded. |
Old enough to know better
Motorcraft are actually a very good filter. So stick with the OEM.
I'm not sure of the oil spec for the Fiesta. 5W-30? I have preferred oil brands.....but basically you get what you pay for. ie a cheap oil is usually just that...cheap
Ryco have a no drain back valve
Zoom Zoom
So does the Motorcraft.
2012 Mazda3 MPS
IMO Motorcraft oil filter is pretty decent so.. just get those.
For the oil, I use Castrol EDGE 5W-30... it's much better than the oil that came with the car. 15,000km service interval is fine if you're running high-quality synthetic oil. |
I use semi synthetic penrite oil and never had any dramas with it cooking with the turbo.
Awww Mannn, soon as i fix one thing another thing dies ![]() .................................................. ............ Hers - 2006 Ralliart colt :newangel: Mine - 2004 Fiesta zetec turbo :gren: .................................................. ............ |
#8 | |||
![]() Join Date: Oct 2006
Australian Ford/Motorcraft filters used to be made by Ryco before the moved off shore.
In fact historically Ryco/GUD they started out with a strong association with Ford: See http://www.rycofilters.com.au/company Quote:
See http://minimopar.knizefamily.net/oilfilterstudy.html and http://www.aus-cartalk.com/auspoc/techstuff.htm for some interesting comparisons.
regards Blue |
#9 | |||
And from Rycco GUD Annual reports:
regards Blue |
#10 | |||
But since GUD closed Aust and NZ manufacture and moved to outsourcing from Asia and South Africa I have been less keen about their products.
http://www.gud.com.au/downloads/pdf/ar05.pdf Quote:
regards Blue |
Thanks for the info, aussiblue.
#12 | ||
GUD also own another Oz icon Victa mowers and with cheap Asian mower imports and drought driven lower mower sales (see http://www.current.com.au/news/article/AVUKDZOEWF) you can see that going offshore as well.
regards Blue |
#13 | ||
Buy the genuine filter from Ford (Motorcraft) so there is no "issues" with your warranty if any problems should arise down the track.
I also used to use Castrol Edge Synthetic in my Fiesta and changed the oil every 5k. |
#14 | ||
You might find the GUD/Ryco warrenty better than the Ford one. see http://www.rycofilters.com.au/company/warranty
regards Blue |
#15 | |||
The genuine oil filter for the Fiesta is the Motorcraft one, if anything other than genuine one is used they "could" get difficult in the event of a warranty claim "if something untoward" were to go wrong mechanically. Personally I would and always did stick with the genuine one, it costs about the same anyway, not like it's twice the price or something. |
