Old 30-05-2005, 07:09 PM   #1
stockstandard
Default Fan speed #3
When I set the AC fan speed to 3 in my EF the fans surge/stop working periodically (like every 10-15 seconds). I think it will just be a dirty contact or something simple, just wondering if anyone could pin point the cause for me before I pull the dash apart.
cheers
Mark
Originally Posted by casper
Yeah, the car is ugly, I can live with that.
stockstandard is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2005, 07:42 PM   #2
EA_Bender
Hmmm Gold!!!
EA_Bender's Avatar
man thats freeky...... mines just started doing that too.... lucky im not going to need it coming into winter. pretty sure it would just be a dirty contact
bender
1990 EA Series 2 Fairmont, Low Springs and shocks, 17 x 7 Advanti Flash Mags running on Falken rubber :, EL XR8 Sway Bars, NGK Iridium Plugs, New Trip Comp, Pacemaker 4480, 2.5 system 4L ED engine with surecam
Now Sporting - OED666's 202+ RWHP engine!! :dj: fully
EA_Bender is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2005, 08:45 PM   #3
Fairlane
V8 Powaah
Fairlane's Avatar
Yeh mine did that but it's fixed now.
Took it to an auto electrician, turned out it was a faulty fan speed resistor.
You can either take it out or put a new one in
*No need to pull dash apart, it's near the Air con intake in Passenger footwell
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2005, 09:14 PM   #4
stockstandard
ahh, just the kind of info I was hoping for. Thanks for that - you might have just saved me a lot of time
Old 30-05-2005, 09:15 PM   #5
SileNceR
02/90 EA II Fairmont
SileNceR's Avatar
mines done that for ages... doesnt do it on 1,2 or 4... just 3
so i just avoid it lol
211RWKW EA
SileNceR is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2005, 09:24 PM   #6
Fairlane
V8 Powaah
Fairlane's Avatar
Yeah, if you got a Gregories manual it's all in there, pretty easy job.
Anyhow this is whats in the Gregories Manual
1. Remove the Glovebox Compartment
2. Disconnect & remove fan wiring connector from mountin bracket
3. Remove screw and withdraw the bracket plate
4. Disconnect wiring connector and remove the retaing screws from Resistor
5 Remove resistor from housing
DONE
Old 30-05-2005, 09:26 PM   #7
stockstandard
That is what I have been doing - but 2 is not enough and 4 is to much. One of those little things that is really ****ing me off!
Edit: Thanks fairlane
Old 30-05-2005, 09:33 PM   #8
Fairlane
V8 Powaah
Fairlane's Avatar
Yeah, # 2 sucks it just aint enough air and #4 is too bloody noisy. lol
Old 30-05-2005, 09:52 PM   #9
stockstandard
ok, I guess this is what I was after
Old 30-05-2005, 10:34 PM   #10
EA_Bender
Hmmm Gold!!!
EA_Bender's Avatar
haha love all the crap in it...
if hate to see mine, parked outside under a tree 24/7, might pull it out on the weekend...
Old 30-05-2005, 11:08 PM   #11
stockstandard
and there is plenty more crap in the box!
I cleaned out the leaves and hooked it back up. Now I can see little arcs comming from where the coils crimp onto the terminals each time the fan slows down. I reacon all they need is a clean up and little solder to fix up the connections and shell be good to go.
Old 31-05-2005, 07:29 AM   #12
bindi
Redhead extraordinaire...
bindi's Avatar
SAME!!! How freaky is that? I just figured it was cos it's an EA lol.
Bindi
88 EA- his car
88 Rolla - MY car
Originally Posted by big_waity
Oh, and another surefire symptom will be the Falcon badge at the back.
bindi is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2005, 09:10 AM   #13
Polyal
The 'Stihl' Man
Polyal's Avatar
haha this is weird.
My fan is crazy, Ill leave it on 3 and it will work for about 2 mins, then stop, then start for 15 seconds and stop again. If Im lucky it will start up by itself but usually I have to switch it to 2 or 4.
And your right 4 is to much!
I thought this was just an EA thing to because my last one did the same thing. And to make it worse the vents barely work at eye level, the screen demister is fine and the ones at my feet just work.
I really need to get it fixed :(
  • 2017 Toyota Prado (work hack)
  • 2017 Mitsubishi Pajero Sport
  • 2003 CL7 Honda Accord Euro R (JDM) - K20A 6MT
  • 1999 Lexus IS200 - 1G-FE Turbo 6MT
  • 1973 ZF Ford Fairlane
Polyal is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2005, 11:06 AM   #14
InitialD
Low and Loud
InitialD's Avatar
Originally Posted by Polyal
haha this is weird.
yeah mine did that aswell.. was the good excuse to put Climate Control in ;)
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car
1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon :
InitialD is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2005, 07:32 PM   #15
SileNceR
SileNceR's Avatar
4 is fine i just turn up the tunes to suit
211RWKW EA
Old 31-05-2005, 09:56 PM   #16
gtfpv
GT
gtfpv's Avatar
what a co incidence my el has just started doing this as well about 2 weeks ago . had no idea what could be causing it . there ya go
gtfpv is offline   Reply With Quote Multi-Quote with this Post
