Old 30-10-2007, 05:10 PM   #1
nix-351
nix-351's Avatar
Question Can you stroke a 250x flow to 278...?????
hi guys i picked up a tf cortina the other week for a spare boody ...he said it's got a n/a stroked 250 x flow to 278 , cast iron head , can it be done ???? and has annyone done it ....???????? IT goes hard ....ran it aginst my bros r33 it killed the r33.....
: turbocharged 250 stroker
nix-351 is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2007, 05:00 PM   #2
P100 Ute
P100 Ute's Avatar
it is possible according to things other people have done.
these r two quotes from 2 different ppl on other forums who have done this.
Originally Posted by Leee View Post
Standard Big End Size - 2.123
Offset Ground to - 1.967
Increase in Stroke of - 0.156.
Standard Stroke - 3.91
Add Offest of - 0.156
New Stroke - 4.066
Standard Bore - 3.680
Overbored by - 0.120
Net Bore Size - 3.80.
Bore Size - 3.80
Stroke - 4.066
Cylinders - 6
Cubes - 277 approx.
Which is near enough to 280 cubes IMHO.
I have a motor that I have done this to. It is currently pulled down for inspection, and I will post pics of the internals if you guys want them. Oh, BTW, Rods are datsun, pistons are Holden.
Check here if you feel the need.
http://car.race-cars.net/calculators...alculator.html
and
Originally Posted by Stroker
Reply for enquiry regarding a stroker kit.
Well I have strugled keeping my Bored/Stroked Stage 4 Cross Flow
together for the last 3 years (been costly, would not recomend it)
however I finaly have it sorted!!!!!
To start, its now stroked to 280, and it consists of an aray of strong parts (I say this cau's I do like to give it a hard time, love to be sideways) here we go:
Hardend crank, performance harmonic ballancer (good for 8000rpm) nissian rods, high tensile bolts, 60thou over toyota pistions,
10:1 compression, Stage 4 CamTec cam, ported & polished head oversize inlet & exhaust valves, heavy duty springs to suit cam. Still running slightly modified (but STOCK) rods & rockers. Induction is currently a redline manifold with a 4 barrel 460 holly bolted to it. A set of pace maker extractors & a 2 & a half inch free flowing exhaust, and last of all
a PRO COMP dizzy & ignition with a standard 12v coil. (revs like thers no tomorow)
Injection, Roller rockers, and a turbo are part of a new project. :
P100 Ute is offline   Reply With Quote Multi-Quote with this Post
