30-05-2005, 07:05 PM | #1 | ||
Custom User Title
I have a 1989 EA S-pac and it has to go in for aroadworthy cirtificate before I can change the rego over. It is an ultra rare 3.9 that DOESN'T leak oil :P, doesn't blow too much smoke etc, tyres are 3 moths old, it is all good. However, the rear right hand passenger seat belt doesn't retract. It pull out fine, but just won't go back in. Will this be a cause for my car to fail a roadworthy inspection?
30-05-2005, 07:11 PM | #2 | ||
It would in Victoria.
30-05-2005, 07:14 PM | #3 | ||
try fixing it ?
Or Just pull it through from behind. I doubt they're gunna test your rear seatbelts. |
30-05-2005, 07:22 PM | #4 | |||
Off smelting
30-05-2005, 07:25 PM | #5 | ||
Damo, in Vic you have to test that all seat belts draw, retract, don't have frayed edges, lock when pulled and are firm in the buckle. Rear belts included.
I'm guessing the ACT will be the same. |
30-05-2005, 07:38 PM | #6 | ||
ahh fair enough. My mums old Galant passed a recent roadworthy, and the seatbelts in that were pretty dodgey, ciggy burns, frayed, and the middle one was difficult to plug in.
Just fix it Selekta, can't be that hard. |
30-05-2005, 07:58 PM | #7 | ||
Yeah, just go grab one from a wreckers. But make sure you check it before you get it, you can't pull them out unless they are mounted in the car.
30-05-2005, 08:09 PM | #8 | ||
I'd get the inspection done; If they pick it up, get it fixed ASAP; if they dont, fix it at your lesiure. A number of ACT inspectors are not that thorough...
Current Rides: 2000 AU 5L XLS ute; 1970 Mustang project |
30-05-2005, 08:36 PM | #9 | ||
RAGE Engineering
Short answer, yes, it is a roadworthy item. Anything wrong with any of your seatbelts you'll fail. However, many don't even bother to look. Get it roadworthied, and if they pick it up, I'd fix it then.
If it doesn't fit, use a BIGGER hammer |
01-06-2005, 10:25 PM | #10 | ||
Custom User Title
Seatbelt is fixed. It's one thing after another. *sigh*
When the car stops, it drops about 200ml's of coolant...no more, no less...will this be a cause for concern? |
01-06-2005, 10:31 PM | #11 | |||
Detroit Locker Equiped TM
Where is the coolant coming from? Engine? Radiator?
Apollo Blue 1974 XB Falcon GT, 557 HP Blue Pearl 2004 BA FPV GT, 290 kW Quote:
http://www.facebook.com/FalconGTClubGeelong |
01-06-2005, 11:13 PM | #12 | ||
Custom User Title
Radiator.
02-06-2005, 08:30 PM | #13 | ||
What if you don't top it up?
Does it still drop the 200ml on the next trip??
