Old 05-06-2005, 12:49 AM   #1
mons2b
Red face My EB2 has a weird clicking noise can you help?
Hello everyone
Since I bought my EB2 and have started driving around with the sounds off to enjoy the smooth burble of the straight six I have noticed an annoying sound..
When I apply the throttle I can hear a distinct clicking noise coming from I think the left hand side? When I lift my foot completely off the pedal and coast then the clicking stops. When I gas it again the clicking comes back.
The clicking is very similar to the sound a crappy old front driven car makes going around a corner. But ive got the damm clicking going in a straight line in a rear driven Ford! Sigh.. please help.
One other thing while I have you it is normal to hear road sounds thru my drivers door do these EB2's have bad door seals sometimes or has mine had a wack? Thanks for your help everyone who answers.
EFII Futura in green. Got to be :voldar02: good for you.
mons2b is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2005, 09:09 AM   #2
NZ
NZ's Avatar
might pay to check out your engine mounts man
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
NZ is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2005, 12:35 PM   #3
Curtis
could be:
your purge valve touching the body of your car
Pinging (Use Higher Octane Fuel, Check Ign. Timming, Check Compression And Temps)
Lifter Noise (Use Thicker Oil, Replace All Lifters, Check Rocker Arms For Wear)
Ceck coil arcing on block
Check worn main bearings
Check Chain and Guides
Itll be one of them, hope its not some of em.
Old 05-06-2005, 01:33 PM   #4
SileNceR
02/90 EA II Fairmont
SileNceR's Avatar
trailing arm bushes?
211RWKW EA
SileNceR is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2005, 02:14 PM   #5
MustangNicko
MustangNicko's Avatar
If its just a ticking noise when you hit the juice then it will be injectors. Its just noisy valve pulse operation in the injectors.
MustangNicko is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2005, 11:29 PM   #6
mons2b
Question Injectors
If its noisey injectors can it be made quieter? The sound comes from the left hand side (passenger).
The sound ONLY comes when I put touch the go pedal. Its like "click click click click" etc...
Sigh... Got to love old cars eh? :
Old 06-06-2005, 12:08 AM   #7
MustangNicko
Its not old cars mate, my car does it too... then again thats almost 10 years old :/
Old 06-06-2005, 09:32 PM   #8
Curtis
Injectors are only so noisey, you shouldnt really hear them from the drivers seat unless they are very large high-flow injectors, but you usually only just hear them at idle. check all these:
Your purge valve touching the body of your car
