Old 07-06-2005, 01:15 PM   #1
EA2BA
PM me if you want
EA2BA's Avatar
Default Timing question ??
In the below pic (option 1 or option 2)
Option 1 : If the timing mark goes more towards or past IGN is that going further advanced.
Option 2 : If the timing mark goes more towards or past TDC is that going further advanced.
Old 07-06-2005, 01:21 PM   #2
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
The balancer goes clockwise and comes to ign before TDC, the more left of ign the more advanced it is.
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2005, 01:23 PM   #3
neb
hibernating
neb's Avatar
option 1 .... i think
neb is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2005, 01:24 PM   #4
ratter
ratter's Avatar
yes option 1 is correct, that's what I meant
Old 07-06-2005, 01:32 PM   #5
EA2BA
PM me if you want
EA2BA's Avatar
OK then now for another question:
in 1st gear full WOT car revs to 4,800 feels like no legs are left, revs but not alot of action then changes gears, used to get out to 5,200 and a good clean change.
Does this mean timing too far advanced, or too retarded.
Old 07-06-2005, 01:41 PM   #6
svo347
AFF's 1st DM.......
svo347's Avatar
advanced.
FORD GIVING POWER TO THE PEOPLE
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
I know what lengths they go to to ensure it's more than just a Ford sticker on the part. Ford doesn't throw it's name on anything for a quick buck.
06 Turbo Terri AWD 6 sp in Neo with stuff i didnt even need, side steps,15.2 inch roof mounted DVD,Pioneer $tezza,Selby 30/18mm swaybars,debunged,100 cpsi Ballistic cat,Plazmaman under battery Cai injectors 14/lb boost,ZF tuned,Xtreme's magic. :
svo347 is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2005, 01:43 PM   #7
svo347
AFF's 1st DM.......
svo347's Avatar
You advance the timing to get peak revs lower in the revrange, to retard the timing brings it on later obviously, allowing the power to come in later
13.21 @107.7mph
Old 07-06-2005, 01:45 PM   #8
EA2BA
PM me if you want
EA2BA's Avatar
thanks guys, will back the timing off and see if I can hit the peak revs like i used to, then i will be happy.
Old 07-06-2005, 08:27 PM   #9
needturbo6
ooga-lagga-ligga-lagga
needturbo6's Avatar
why are you going for peak power, 3.9L have none in stock form especially at 5200rpm? is your motor much modified?
needturbo6 is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2005, 08:42 PM   #10
ratter
ratter's Avatar
The timing curve in the computer is set at the factory and probably not ideal for max power, but retarding it to get more power will not work if it is set correctly, if you retard it too far it will be gutless and slow to rev at all points of the rev range and if retarded enough will run hot, and if you advance it too far it will rev quicker, probably get slightly better economy but may start to ping, if it pings it will drop power anyway but you will stand the chance of doing engine damage.
What fuel are you running, if running 98 octane you should be able to advance it a little more than the recommended figure without it pinging
Have you altered the timing to start this problem, because the timing should not change unless the distributor is moved.
You may have another problem that is causing the loss of revs - dirty air filter etc
Old 08-06-2005, 08:14 AM   #11
EA2BA
PM me if you want
EA2BA's Avatar
ratter, yes my air filter needs a clean, and I am running stnd unleaded (used to rev 5,200rpm on that too) but when I replaced the timing case and a broken guide the chain moved, so I had to reset all the timing, and hence it is out i believe, I have set it 'about' right, but think it is a little to advanced at the moment, I didnt get a chance last night, so tonight I will be adjusting and some test'n'tune to see how it goes.
Old 08-06-2005, 09:17 PM   #12
EA2BA
PM me if you want
EA2BA's Avatar
OK, backed the timing back a little bit, engine feels heaps better and now revs out then changes gear and keeps on going, could probably be backed off just a smidge more, but for now I am happy
Old 09-06-2005, 08:24 PM   #13
ratter
ratter's Avatar
Glad you got it sorted
