Old 15-06-2005, 02:27 PM   #1
MintEAFalcon
1990 EA Falcon S Driver
Default New DBA Rotor Wear...
Hi guys,
I have a question regarding the calipers on the front of my EA. I replaced the standard (and warped) rotors with DBA slotted about 3 months back as well as chucking on a new set of Bendix Advance pads.
Concern #1 is the way the pads are using both rotors. The inside pads on both sides are using all of the rotor, whereas the outside pads are only using about two-thirds (About one third of the rotor closest to the hub has no wear marks). Do I have a major problem here?
Concern #2 is the movement of the caliper itself on the slides. I can actually move the caliper left/right and up/down on the slide (as opposed to its normal in/out motion). Its not a huge amount but a concern none the less. Are my slides stuffed?
Any thoughts appreciated! Thanks guys!
Mark.
MintEAFalcon is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2005, 06:50 PM   #2
NZ
NZ's Avatar
your slides need grease. use a high temp grease and if the rubber boots are stuffed replace them. dry slides will cause your brakes to drag on one side.
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
NZ is offline   Reply With Quote Multi-Quote with this Post
