Old 16-06-2005, 01:01 AM   #1
Kaddis
Kaddis Customs
Kaddis's Avatar
Default AU steering wheel into an EF?
just wondering am i able to take a steering wheel from an AU xr and put it into my EF??
anyone know if these are hard to find/expensive??
FG XR6 E-Gas Ute in Ego
Kaddis is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2005, 01:01 AM   #2
InitialD
Low and Loud
InitialD's Avatar
Yes AU wheels will fit EF/EL
EFFALCON has a AU one if im correct..
that steeringwheel is availble on EBay and sold at ford aswell... Blue/black/Silver/Red are the colours available IIRC
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car
1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon :
InitialD is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2005, 01:09 AM   #3
Kaddis
Kaddis Customs
Kaddis's Avatar
nice! i found them for about $275 but that's without the center pad or any of the center
main reason why i was looking for another wheel is because my air bag isn't working and im 95% sure it's the actual bag
Old 16-06-2005, 01:21 AM   #4
EFFalcon
Last warning
EFFalcon's Avatar
the air bag is an expensive replacement.
how do you know the air bags not working?
there is a problem that when the air bag fuse blows, u have to reset the system to clear the fault.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 16-06-2005, 01:27 AM   #5
Kaddis
Kaddis Customs
Kaddis's Avatar
how do you reset the system then?? caus the horn was not working i checked the air bag fuse and it was blown so replaced that then reconnected the horns(don't know why there were disconnected:S) and the horn works fine now but air bag like still is on
when i first start the car and in say the first minute of so it kinda comes on and off then eventually stays on
also what can caus the air bag fuse to blow?
Old 16-06-2005, 01:35 AM   #6
EFFalcon
Last warning
EFFalcon's Avatar
yep
you need to reset the air bag system.
if you're not a member on fordmods, then join up and look here:
hxxp://www.fordmods.com/phpBB2/documents.php?doc=3
look at the section on clearing codes.
Old 16-06-2005, 02:59 AM   #7
MrQuan
Social Disaster
MrQuan's Avatar
Does that mean you can use your existing EF steering wheel center or something? :
1995 EF Falcon GLi, Auto, 4.0L I6
Mods:
3.73 LSD | Darkest legal tint | tinted back lights | Sprayed Dash | Custom Trims
Sound System:
Fusion front splits, rear 3-ways, and 2 x 12" subs with ctrl, 3 x Fusion amps | Clarion HU | 1F Cap | 60GB Zen Xtra | 800W RMS output!
MrQuan is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2005, 07:08 AM   #8
elxr6
are they much thicker then the el xr6 steering wheel?
Old 16-06-2005, 08:32 AM   #9
Kenaz
Kenaz's Avatar
Yes, I believe so.
02 BA XR6 T U R B O
Venom Red, Auto 13.97 @ 101mph
Originally Posted by Wheels Nov 02
It's suave, more subtle, and yet no less stirring. In fact, the boosted Ford is more polished than any big sedan Australia has ever produced. It's just so damn good, it makes the SS feel crude... Ignore the WRX. Forget the E49. Falcon XR6 Turbo is king.
Kenaz is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2005, 11:57 AM   #10
EFFalcon
Last warning
EFFalcon's Avatar
Yeah, AU and EF/EL wheels are interchangable.
you can just whack your EF/EL airbag onto it and you're laughing (except for the colour)
i painted mine with vinyl dye so its black like the steering wheel, been good so far
mrbt1: the AU momo steering wheels are an awesome wheel to hold, much nicer to hold then the normal XR ones.
Old 16-06-2005, 09:38 PM   #11
INJECTED_250
Custom user title
INJECTED_250's Avatar
If the horns not working and the air bag light is on.. Clock spring is most likely broken
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2005, 09:40 PM   #12
EFFalcon
Last warning
EFFalcon's Avatar
the horn works fine now :P
