Old 17-02-2008, 09:38 PM   #1
tankclare
BURN RUBBER NOT OIL
tankclare's Avatar
Default Ebay..scam or not?
http://cgi.ebay.com.au/UNLOCK-your-d...QQcmdZViewItem
must be fake..if not how do you do it
[TUFF4L] EF Fairmont Ghia build thread - http://www.fordforums.com.au/showthread.php?t=11381891&highlight=tuff4l
[SMOKES] FG XR6 build thread - http://www.fordforums.com.au/showthread.php?p=4795218#post4795218
tankclare is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2008, 09:40 PM   #2
ILLaViTaR
ILLaViTaR's Avatar
I've actually heard you can do it.
That guy makes it sound like a video game or something lol.
EB II 1992 Fairmont - koni reds, wade 977b, 2.5inch/4480's and much more to come!
ILLaViTaR is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2008, 09:45 PM   #3
XR8 Uterous
Few threads on here and ford mods will tell you how to do it all for free, just search.
XR8 Uterous is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2008, 10:32 PM   #4
V3RSAC3
... Fear it!
V3RSAC3's Avatar
all you have to do is hold ur odo. meter down for a random of various seconds ... i'll dig up the thread for ya
Originally Posted by Mr Hardware
Just remember gents, anyone can follow fashion, but it takes someone with real class and finesse to have Style.
Chrysler 300C Sedan
SY Territory Ghia
V3RSAC3 is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2008, 11:00 PM   #5
the_scotsman
MY21.5 Mustang GT
the_scotsman's Avatar
For EF/EL (taken from Fordmods.com):
The diagnostic mode can be entered by using the following method
1) With the ignition key in the off position, press and hold the Odometer reset knob for 10 seconds.
2) whilst holding the button in, switch the ignition to the on position. (Note : It is not necessary to start the car).
3) With the ignition on, press the odometer button 3 times in quick succession.
4) On the third press, hold the odometer button down, until the Seatbelt lamp is no longer illuminated.
5) The Odometer should blank out. After a period of 10 seconds, the display will flash FORD
<li>6) Press the Odometer button again to go to the first Diagnostic mode
To view the next diagnostic mode, press the Odometer button for about 1 second
To view the previous diagnostic modes, press and hold the Odometer button for about 2 second
To Exit the Diagnostic mode, hold the Odometer Button until the Odometer display returns to normal
The codes and their meanings can be found HERE at Fordmods.com
the_scotsman is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2008, 11:02 PM   #6
the_scotsman
MY21.5 Mustang GT
For AU:
1) With the ignition key in the off position, turn the Ignition Key to the On Position.
2) Using the Odometer Button, Press the Odometer Button Down, then release 5 Times within 10 Seconds (Note : You must be very accurate with the timing. Depress the Button for 1 second, then release for 1 second. Do this 5 Times in 10 seconds)
3) Release the Odometer Button for 5 seconds.
4) Depress the Odometer Button for 7 Seconds.
5) Release the Odometer Button for 5 Seconds.
<li>6) Depress the Odometer Button for 7 Seconds.
You should now be within the AU Instrument Cluster Diagnostic Mode
Within Diagnostic mode, there are 19 Diagnostic Screens that are available.
At the moment we do not have enough information as to what all the screens actually are.
To Exit the Diagnostic mode, Depress the Odometer Button for 11 seconds.<li>
Meanings of the codes can be found HERE on Fordmods.com
Old 17-02-2008, 11:03 PM   #7
the_scotsman
MY21.5 Mustang GT
I can't believe people are selling this information on eBay...making money off something like that is scandalous...
Old 18-02-2008, 10:39 AM   #8
flappist
Yep sure is...
Now I have this peice of toast that is shaped like a suparoo badge from a XY GT, what is the openning bid........
flappist is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2008, 01:47 PM   #9
davez104
Landau = GT with the lot!
davez104's Avatar
Does anyone know if this works the same for BF?
davez104 is offline   Reply With Quote Multi-Quote with this Post
