19-02-2008, 04:12 PM | #1 | ||
I want to replace the wipers (just the rubber) on the wp fiesta. Are there any good aftermarket ones or should I just buy them from ford.
Also what size do I need to get? thanks |
19-02-2008, 05:09 PM | #2 | ||
They're 24" IIRC
I personally use any silcon type replacement, the rubber ones don't last long in the sun They shouldn't cost anymore than $10 a pair from a department store, or even cheaper at a repco, bursons etc..
2004 Fiesta Zetec Colorado Red Elbach Lowered Coils - Rear sway bar - 12.5mm Axle Spacers - Rear disc brake conversion - 16" MP3 Rims Tinted windows - Tinted Headlight surrounds - Clear side indicators- Phillips Xenon lighting - Colour Coded - ST Rear Spoiler - Smooth Rear Wiper - Ford leather gear knob & boot – Zetec S Sill Covers & Steering wheel - Leather centre armrest - Pioneer USB/CD player - JL Audio 4ch Amp, subwoofer & splits - Short aerial The most "Standard" car I've ever owned!
19-02-2008, 06:12 PM | #3 | ||
Old enough to know better
A bit more than just the rubber, but check out Bosch Aeros Twins at Supercheap Auto.
Brilliant. Whisper quiet and far more effective performance. (Probably about $50 for the pair....but some guys I know say it's the best bang for buck mod they've made!) http://www.bosch.com.au/content/lang...l/715_5615.htm
19-02-2008, 06:32 PM | #4 | |||
04 fiesta zetec
i'll second that, got some a little while ago, they are a lot quieter and look awesome! just look on the back and see if they fit an LR focus, mine worked fine. but just test one first to see compatibility. i think i got a 22" and a 16". just measure your existing ones with a tape and try and match em. |
19-02-2008, 07:11 PM | #5 | ||
I was tempted to try these when i recently got my new wiper blades
Silicone blades work 100% effectively as they are designed to, and are whisper quiet... but the bosch ones do look pretty neat : but other than looks i didn't think they were worth the extra cash IMO..($ x5 = : ) If you want a noisy blade try those twin ones... I unfortunately did once and they bloody whistled at speeds above 60KPH :togo: we live and learn i guess
19-02-2008, 08:19 PM | #6 | |||
04 fiesta zetec
EDIT: actually i bought the Aunger ones. little cheaper, look the same. but i haven't had any troubles with whistling over 60kmph. dunno how long they last though...... |
19-02-2008, 09:56 PM | #7 | ||
I previously used silicone blades.......squealed like buggery
20-02-2008, 08:43 AM | #8 | ||
thanks for all your quick replies. I'll check them all out and let u know which ones I got in the end.
