Hi All,
I own a 91 KF Laser 1.6 Carby Manual. On my way into work this morning about 15 minutes after starting off the car started to jump when accelerating. It seems most pronounced at 1/6-1/2 throttle. If I floor it it seems OK but a bit sluggish. Also when I revved the car in neutral at part throttle it would almost stall before revving. This made taking off quite jerky. Anyone have any ideas on what it could be? It doesn't happen all the time either. Maybe once every 3-4 weeks. Cheers Sam |
Over Thinker
second stage of the carby not working
choke problem a vaccume leak vaccume pot devices not operating on the carby water/dirt in fuel filter sticky accelerator if a cable or a spark problem coil cap plugs leads dissy module
My car goes Brumm Brumm |
Thanks for the reply.
I might take a look at the carby on the weekend. Anything to look out for when I do? Cheers Sam |
Over Thinker
just spray wd 40 around the carby pivot points
start the car without the air filter on and see if the top butterfly opens see if you have a clean air filter clean the battery terminals pop out in the dark lift the hood and start the motor look for arcing at the coil cap or sparkling leads
