Saving for a Jet Car
Well, some of you may know about my recent running probs with the XC.
Timing was out to buggery, got it sorted and it ran better. But i got sick of a little better and had it taken further. Turned out 3 valves were burnt out, so that was fixed up. Ran better than i can ever remember for a few days and i was immensely happy. But was asked to take it back as my vac advance needed some more minor adjustment and probly a regraph as it couldnt be adjusted any further. On the way home the other night, began running rough again. So i baby it home that night and run it back down again to my trusty mechanic next morning. Turns out, now ive blown a head gasket between Cyls 1&2. Apparently it doesnt look too bad, no damage to block or head. Looks as though i might get away with a gasket replacement. Although, he wants to have a closer look before continuing. So im hoping it have the car back on the road sooner than later. The Mrs wants me to upgrade now, so that might happen too.
RIDES 2011 SZ Territory Titanium TDCi - Smoke 2001 Mitsubishi "BONSAI" GSR Mirage - see thread |
LOL, While ive remembered it. :hihi:
I forgot a mate of mine was trying to sell a worked 351 from his XC, built for 400HP. I wonder if he still has it... And if i can knock him down a few $$$ on it. I was saving $$$ for a box & diff upgrade, although im not sure it would handle that engine for long. I'm sure the Mrs would have something to say about that idea... LOL :Up_to_som
Well we are 99% sure the source of my problems has been found.
It turns out my timing troubles were the result of a broken "roll pin" in my electric dizzy that was installed last Feb. With it broken, the bottom of shaft was just moving around willy nilly advancing and retarding it back an forth, obviously not a very good thing. Upside is no damage to the block or heads ![]() Although, they are getting cleaned up just to be safe. You can sort of see the roll pin in the picture below, just above the teeth of at the bottom of the shaft. A part that costs only a few cents brings it all undone...
FTF Club Moderator
What does the misses want you to upgrade to?
I hope everything is ok with Barney. Whats the plan from here?
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
#5 | |||
![]() I had the same thing happen to my XF when I had it Andrew. But mine went at around 5000rpm,made a bit of a mess. |
#6 | ||||
I was hoping for a Fairlane, get some pimpn LWB going ;) Will either be a AUIII or up to a BA of some sort. Looking at a XR or Fairmont. Quote:
![]() I'll keep that idea in the pipeline. Im just lucky when mine came undone that was was only cruising at 80km/h And only a few kms run to the workshop from there.
Well, my heads are back and bolted on.
They were given a light shaving and pretty much reco'd again, just to be safe. And some new FELPRO Gaskets, Im told the FELPRO's are good. So good as new again. The dizzy is back together(with new roll pins) should be running today or tomorrow ![]() I cant wait ![]()
