Old 19-03-2008, 08:06 PM   #1
Pazuzu
Default Mk. 2 Essy wiring question
Hi all.
Am trying to get my reverse lamps to work in order to pass safety inspection. I've checked the globes, cleaned and tested the connections, but no luck.
I see on the wiring diagram in the manual that an earth lead goes from both reverse lights to a reverse lamp switch, which is earthed.
Can anyone tell me where the reverse switch is located? Logic tells me somewhere on or near the gearbox, but if anyone knows for sure then I would really appreciate the help.
Cheers and beers,
Dan.
Pazuzu is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2008, 09:46 PM   #2
Roy Rogers
It screws into the extension housing right next to the gear shift. It is easyer to see from underneath.
President
Small Ford Car Club of NSW
www.smallfordcarclubofnsw.com.au
Roy Rogers is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2008, 07:25 PM   #3
krt10
eskyman
krt10's Avatar
yup, there should be a plug coming out the side at the end of the switch which, as stated, can be easily seen from underneath. check that the wire is there and in good condition.
who says kents cant be quick
krt10 is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2008, 05:55 PM   #4
Pazuzu
Thanks for the help, guys.
