Turbo Falcon Fiend
Hi,
I just thought I would see if anyone on this forum knows how to modify the AU transmission using resistors. A gentleman was going to help me, but I think he has been waylaid. I have10 x 5 watt 33 ohm resistors (I think I need three) and I believe they are meant to go somewhere on the wiring for the trans. I just dont know where. I looked at the mod on the AU falcon site, but it uses different resistors. I have to drive to Sydney on Sunday and back on Monday I just want to give the trans an easier time. Can anyone help me??? Roy |
what is it meant 2 do??
Irregular member
I think there are some circuit / wiring diagrams uploaded by Russel somewhere on this website.
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny My hovercraft is full of eels! Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971). |
![]() Join Date: Dec 2004
Theres an article by Useless in the workshop section of aufalcon.com too.
TL40 Wagon?
33 Ohm 5 watt are no good mate.
theres lots of different combinations you could try but not 33 ohm unless you parallel a few which will get you close to the correct resitance and power rating. You need 10 watt or two 5 watt resitsors in parallel for a start. You should get a SPDT switch 10 amp 12v to turn on and off. Find Pin 81 on your ecu (take it out) and trace this wire back in the loom under the glove box and cut it. Connect the ecu side to the centre of your switch. Also connect the centre to a 5.6 Ohm 10 watt resistor (or two 10 ohm 5 watters in parallel). Connect the other side of the resistor to the transmission side of the pin 81 wire and also to the off contact of you switch. Now splice into pin 71 and run a wire to the on contact of your switch with an 18 Ohm 10 watt resistor in series ( here you could use your two 33 ohm 5 watters in parallel which are close enough). Good Luck. It does all work but you may want to experiment with the values or build an adjustable one like useless has posted up in AUfalcon.com |
Turbo Falcon Fiend
The mod is meant to assist the trans in dealing with more power and positive manifold pressure.
Thanks for the tips. EA Turbo Ghia was suggesting the mod using the 5 watt 33 ohm resistors. I have been trying to PM him but his PM box is showing as full. Is it possible he is using a different mod? Has anyone heard of such a mod? I think Dansedgli also did this mod? anyone??? Or am I better of just doing the mod as described above by jonbays??? Roy |
Can anyone tell me if there is an adjustable shift kit that i can buy ready to install and then just give it to a auto electrician to fit.
I have read the article by Useless and as easy and well explained as it is i just dont trust myself to go messing around with the ecu. I did read somewhere awhile back that you can buy a kit with an adjustable knob that you can adjust from a soft change to a hard change that will chirp the wheels if so desired. Thanks in advance Gary |
Smile
pm me for advice.See the site aufalcon .com...I wrote the article using real life experiences.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
Give me 2 seconds and Ill post the wiring diagram. This mod is more suited to cars with more power than the other shift kit everyone else has.
It is very harsh but stops all slipping. I tried the other kits you guys mentioned and it would still slip bad on gearchanges when on boost.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
Here is the one I used and it was great. Chirped 3rd
![]() Im not sure if the au uses the same wiring as my EB though. ![]()
Turbo Falcon Fiend
Thanks heaps. I have printed the diagram and will get the whole thing explained to me.
BTW whats DPDT? Can you give me a soldiers 5 on how it works? Thanks, Roy |
#12 | ||
Turbo Falcon Fiend
Any one know if this wiring is a goer on the AU?
#13 | ||
its just a type of switch, ask your local dicksmith/jaycar and they get one for you. Double pole double throw I think.
#14 | ||
Smile
Dont use that on the AU .The resistances a re different on the AU
pin 81 on au ecu
#15 | ||
Its a different type of shift kit to yours Useless. This one bypasses the S5 solonoid allowing the trans to run higher line pressure than if the S5 was electronically adjusted.
#16 | ||
Smile
My one increases line pressure on s5 solenoid as if the solenoid was adjusted too.?
By passing s5 went to limp home.
#17 | ||
This one bypasses the S5 completely.
My trans was fine with the above kit and so are many other E series. Not sure on the AU though. At least its reversable if it doesnt work.
#18 | ||
Smile
you are scaring me.
#19 | ||
Turbo Falcon Fiend
Your scared?
Its My trans! Is there any chance it will damage the trans if it does not work? |
#20 | ||
Smile
I have never tried the kit that dan has the design for .I have tried mine so am not familiar with the other design.If you chose my unit I can help out if you chose the other dan may know better.
#21 | ||
Turbo Falcon Fiend
I am happy to try what ever will give me a definite shift under boost. At this stage I have to back off left it shift and bring it back onto boost.
#22 | ||
The shift kit I posted can just be turned off if you dont like it. It will definatley improve your shift if it is now slipping under boost on gearchanges.
I had mine on for over 6months on a 300,000+ trans running 200rwkw and 10psi without a trans problem. I wasnt even running a trans cooler even though I should have been.
