22-06-2005, 02:50 PM | #1 | ||
Posts: n/a
There must be some trick to getting the freakin pins out of the doors but I can't work it out. Anyone got the knowledge would be greatly appreciated!
22-06-2005, 02:52 PM | #2 | ||
PM me if you want
Dont they have a little grub screw or something to hold them in.
Owner of first ever car to retrofit BA SSS - the EA2BA Send me a PM if you want to know anything 2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
22-06-2005, 10:13 PM | #3 | ||
No special trick. You have to soak them for a week with WD40 or such like. And you need a BIG hammer ...
23-06-2005, 10:17 AM | #4 | ||
Posts: n/a
OK I have both of those items so will give it a try. A week of WD no wonder I couldn't get the b&()((*ds off!!!
23-06-2005, 10:51 AM | #5 | ||
Their are a couple of special tools to get the pins out. One is small tool which goes through the pin, you attach a small 'dog' to it and tap it with a hammer.
The other is a special 'slidehammer' that is really thin. The shaft goes through the pin, you attach a tiny hardened steel nut to the end and then just whack on it like any other slidehammer. You should be able to get either (or both) from a tool/auto shop. Panelbeaters (which I use to be) use them all the time. Commodores have the same type of setup. Ask at a panel shop if you can't work it out. The guys will probably be happy to show you. |
