Old 24-06-2005, 12:29 AM   #1
EFPWR
B-Series Powered!
Default Cut n Polish - what do i do?
I want to do it myself to save some $$, do I need a buff? What brands do you recommend?
2003 BA Futura
Pacemaker 4490's, 2.5" metal cat, 2.5" mandrel bent exhaust, hi-flow air filter, more to come!
EFPWR is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2005, 02:14 AM   #2
pauljh74
pauljh74's Avatar
Personally, I just do it all by hand and use 2 cotton cloths to buff it off - usually old cotton T-shirts made into rags for example. Buff most of the wax off with 1 rag, then quickly again with the cleaner rag. Been doing this for 10 years and looks good. A place for technique tips is Karate Kid part 1
Originally Posted by Mark Webber
Not bad for a #2 driver
Mark Webber after winning the 2010 British Grand Prix.
pauljh74 is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2005, 05:16 AM   #3
Mike Gayner
Mike Gayner's Avatar
Yup I just use rags. Make sure you get the right sort of Cut+Polish as some are designed to be used with a buffing machine only.
Mike Gayner is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2005, 09:46 AM   #4
FNQracing
RAGE Engineering
FNQracing's Avatar
For one of the better car detailing guides, check this http://www.ls1.com.au/forum/showthread.php?t=40605
If it doesn't fit, use a BIGGER hammer
FNQracing is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2005, 10:32 AM   #5
LTDHO
The one and only
LTDHO's Avatar
Hints:
clean car first.
make sure 100% dry
do not do in sun heat
do one panel at a time.
constantly flip rag to keep it clean.
avoid plastics (it a pain to get off)
Tuned by CVE Performance
Old 24-06-2005, 11:36 AM   #6
EFPWR
B-Series Powered!
Thx for the tips guys, appreciated..
Originally Posted by LTDHO
Hints:
clean car first.
make sure 100% dry
I got polish on my plastics and its still on there :(
2003 BA Futura
Old 25-06-2005, 06:34 AM   #7
SVR73
Mr Polish
Got any prepsol or trim restorer type product, that will do it
I'm crying out to you all, please read my car care tips article in technical resources
T shirt & terry cloth rags create micro marring due to the cloth unable to get rid of the polish residue. It sits on the surface of the cloth and even when it looks clean you are wiping residue back over the paint.
The old cars are more forgiving but if you have an AU or BA of any kind, go easy on it with microfibre towels and cloths, doesn't matter where you get them from. stay away from chinese made ones though
Detailology colour fx detail studio and R&D Lab
SA's leader in auto detailing and paint treatments
SVR73 is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2005, 12:40 PM   #8
EFPWR
B-Series Powered!
What would you suggest then? (Im doing it to my EA but still..)
2003 BA Futura
Old 26-06-2005, 03:07 PM   #9
SVR73
Mr Polish
Try the finest product first and move up the grit scale as below
soft polish - light cut polish - 1500-1800 extra fine cut compound, 1200-1500 grit compound, 1000 grit compound use only as last resort
Wash the car and with shampoo still on it, clay the paint well
Use prepsol to remove any waxes or polymer sealants that are on there
try the polishes with a hand foam pad, if doesn't work use a 1500-1800 grit compound.
If you get the results you want, then remove swirls and finer scratches with a swirl mark remover (poorboys ssr 2 - 2.5 , menzerna PO85MF or FP II will do the job
Use a finishing polish to get rid of the remaining marks
Enhance with clearkote vanilla moose, red machine glaze and yellow moose (only clean and enhance, they do not remove paint)
Seal with an acrylic, super polymer or polymer sealant (2 coats minimum), one to two coats of a pure carnuaba wax
With every product use Side to side - top to bottom motions
Clay the glass while your at it
Old 26-06-2005, 05:01 PM   #10
SVR73
Mr Polish
Default help
A couple helpful links for you
http://store.bettercarcare.com/paintpolish.html
Go to bettercarcare.com and check out all the how to articles
I don't agree with everything stated with those but it's very helpful
