#1 | |||
I noticed this morning that local Coles Express* servos have added another layer of sleaze to their petrol marketing: the illuminated discount price is the E10 less 4 cents. Sneaky.
Now E10: my local servo manager said there is no way he would put it in his car. He said if you could see the gunk in those bowser-line filters and on the underground tank dipsticks you'd run a mile before using it. What do others here think? * Quote:
Now XR5hatch!
E10 contains ethanol, ethanol promotes corrosion.
Your car has metal components (fuel lines, engine etc etc). All the petrol tanks at the refineries had to be internally coated to stop the ethanol corroding the tanks. Also if the tanks were not cleaned 100% (which a lot service stations weren't due to cost) it reacts with left over fuel, the untreated tank and creates a sludge like substance & again corrosion. Put this into your car? Personally no way. If you only keep the car for a few years and upgrade, you might take the punt for the savings... |
Sock Puppets
Hmmm, very interesting. Ethonol has other issue as well, like pushing the price of crops that are used in the prouction higher. So basically you save a little at the bowser and then pay more for your groceries. Plus ethonol fuel doesn't last as long. So to actually be a saving it was worked out that it needs to be 5c/L cheaper than normal fuel.
On the Zetec behind the petrol cap is a sticker that reads 'E10 Suitable' I have wondered about that. The Zetec must have the tank coated to prevent corrosion.
Ford Mondeo Zetec Hatch in Blue Ambition |
Now XR5hatch!
My XR5 says "E10 suitable", It will never get anywhere near it though.
#5 | |||
I hope NSW govt doesn't go ahead with its plan to make E10 the only ULP standard fuel by 2010. If you want to buy non-ethanol ULP, you'll have to buy the higher octane ones. Anyway, despite the E10 label, E10 will not put in my Mondeo. |
#6 | |||
Sock Puppets
